Originally Posted By: NVRENUFF
I have a Honda 3000 invertor gen and want it to last as long as possible. It's normal use is to run a 33' travel trailer over a weekend, and power the basics in the house during power outages. Currently I have about 500hrs on it and change the oil @75hrs. I was using the recommended Honda oil but switched to Amsoil EL on my last change. Every time I change the oil I see what looks like tiny copper flakes and that worries me. Hoping to see less of that with the Amsoil. On some of the "off the grid" forums I've seen guys claiming they use plain cheap rotella 15/40, changing oil every 150hrs, and have over 12,000hrs on these generators.
My questions is, what oil is best for oil bath engines to have maximum life? At $2,200 I'd like this gen to last as long as possible.
Thanks!!!
I Bet I won't get one person to agree with me, when I say the following:
Here it goes; Honda's recommendation for all its generators is either straight 30wt or 10W30 ( a generic, non specified, mineral or synthetic based). If you believe that Honda's specified 10W30 viscosity works BEST in all climates, lets start from there. If cost is no object (generator only holds 1/2 quart, so why not open your wallet), lets spring for the 10W30 product with the highest flash point, lowest NOACK figure, and highest HT/HS money can buy. In my book, that cuts it down to one. On paper, these should work just fine.
Taking the Gold medal is: Amsoil MCT 10W30. HT/HS of 3.5, Flash point of 238C, NOACK of 5.4.
Taking the Silver medal is: Mobil 1 10W30 High Mileage - because it can be easily bought over the counter at a reasonable cost and probably has specs almost as impressive.
Taking the Bronze medal is: Chevron Severe Duty 15W30. It is a recently discontinued product. I bought several 4 gallon containers for under $8/gallon. Great hot weather performance for cheapskates like me. This is what I am using. I believe I am getting 9/10 of the performance of the other two, for a fraction of the price.
Full disclosure, I own a used Honda EU3000is. A 2004 model with under 100 hours. I also bought a used Honda EU6500is with over 3600 hours. A 2012 model that came from a steel company. Don't know what oil they used, however, it runs like new, and is now used for standby back up duty at my house.
