Walmart and Valvoline
by Bullwinkle007. 01/22/19 09:10 PM
Getting Our Kicks On Route 66
by 2015_PSD. 01/22/19 08:40 PM
Uploading a short film clip from an IPhone.
by Snagglefoot. 01/22/19 07:52 PM
Purolator L34631 (torn media)
by LDM. 01/22/19 07:51 PM
THIS close to getting a VDB today at TPA
by 14Accent. 01/22/19 07:48 PM
Supco Appliance Parts.
by George7941. 01/22/19 07:36 PM
Unusual Jury summons.
by Chris142. 01/22/19 06:31 PM
Vibration feeling after new tires installed?
by MONKEYMAN. 01/22/19 05:51 PM
Sudden Shake - ‘18 Accord
by Throt. 01/22/19 05:43 PM
05 Ford 500 Intake hole - melted
by Geauxtiger. 01/22/19 05:41 PM
How's K&N 1004 on Kia/Hyundai GDI
by SlavaB. 01/22/19 05:18 PM
more PSD woes with cold weather
by Donald. 01/22/19 05:10 PM
Can someone do a UOA on AmazonBasics oil?
by ThunderOne. 01/22/19 04:03 PM
Any analysis on the Mobil 1 0W-40 ESP Dexos 2?
by fnbrowning. 01/22/19 04:02 PM
Cat sick
by Eddie. 01/22/19 03:49 PM
Lubeguard
by hardheaded. 01/22/19 02:10 PM
OEM Cap & Rotor when changing spark plugs?
by paulri. 01/22/19 01:50 PM
A young boy...
by JLTD. 01/22/19 01:34 PM
73guna, Tedee, JayF, Sam002, Binco
67013 Registered Users
57 registered members (AdRock, bdcardinal, 209paulc, bernardch, 7 invisible), 1,112 guests, and 44 spiders.
Topics297,006
Posts4,963,335
Members67,013
Most Online2,821
Jan 21st, 2019
Best oil for old 12v Cummins, extended drain??? #4288925
12/30/16 01:56 PM
12/30/16 01:56 PM
Conroe, TX
NVRENUFF Offline OP
NVRENUFF  Offline OP
Conroe, TX
I'm sure this will bring all sorts of opinions but I'd like some thoughts on this. I have a couple old first gen Dodges with the 12v, one is stock but turned up a little and the other is built and runs @75psi boost and 4,200rpm. It has 140lb valve springs so it's under much higher strain than stock. All these new oils seem to trade off strength for emissions, so what would be the best oil to run long term in these old trucks? Working in the oilfield I rack up the hwy miles and have extended idle time. I've been running Rotella T6, changing the M1 filter at 6k and oil change every 12k. Looking at Mobil Delvac 1 esp, it's pricey but looks good on paper for extending drain intervals. I like Amsoil but don't like the hassle of ordering online, I prefer over the counter sales.
Thanks for any info and opinions!
Re: Best oil for old 12v Cummins, extended drain??? [Re: NVRENUFF] #4288933
12/30/16 02:06 PM
12/30/16 02:06 PM
Jacksonville, FL
FlyNavyP3 Offline
FlyNavyP3  Offline
Jacksonville, FL
You certainly don't need the ESP in an old 12v. The T6 is (was) a great oil prior to CK-4 so it will be interesting to see what the new spec will do to SA content that's been used for internal engine protection for years but is bad for diesel emissions equipment. Honestly any of the Majors in a CJ-4 should serve you very well. In TX you could even run the 15w40 Delvac or Delo both of which are excellent oils as is the Rotella. My personal choice would probably be the Delvac or Delo in a 5w40 or a 15w40 over the Rotella but that's splitting hairs IMHO.
Luke
Re: Best oil for old 12v Cummins, extended drain??? [Re: NVRENUFF] #4288937
12/30/16 02:11 PM
12/30/16 02:11 PM
Kentucky
Ramblejam Offline
Ramblejam  Offline
Kentucky
http://www.swri.org/3pubs/brochure/ae/pdf/CumminsISB.pdf
The only products I've seen advertised specially for, and touting their superior performance in ASTM D7484 are:
Kendall Super-D XA
Phillips 66 Guardol ECT
These both come from ConocoPhillips, and include their "liquid titanium" additive package.
Re: Best oil for old 12v Cummins, extended drain??? [Re: NVRENUFF] #4288967
12/30/16 02:33 PM
12/30/16 02:33 PM
Kentucky
Ramblejam Offline
Ramblejam  Offline
Kentucky
P.S. -
Originally Posted By: NVRENUFF
M1 filter
Get rid of that filter, and go with Fleetguard LF9028.
http://capitaldieselco.com/images/lube-filter/LT36043.pdf
Re: Best oil for old 12v Cummins, extended drain??? [Re: NVRENUFF] #4289087
12/30/16 04:31 PM
12/30/16 04:31 PM
Northern Kentucky
901Memphis Offline
901Memphis  Offline
Northern Kentucky
Amsoil is good, order in bulk so you have a couple changes handy.
2012 Chevy Cruze LT 1.4T - 59k - Edge 0w30 SL + Mahle OX401D
2002 Buick Century 144k - Built 4T65e(Maxlife) - GTX 5w30 + Fram XG3980
Re: Best oil for old 12v Cummins, extended drain??? [Re: NVRENUFF] #4289132
12/30/16 05:28 PM
12/30/16 05:28 PM
Indiana
njohnson Offline
njohnson  Offline
Indiana
If you really want to run the Delvac 1 ESP, and want to save some money, look for the biannual rebates Mobil is offering. They were offering rebates on the Mobil 1 oils and the Delvac Super 1300 oil for several years already. Starting in 2015? For sure, last year, they offered rebates on the Delvac 1 ESP oils. $12 off for a gallon jug (limit 5) or a $60 rebate on the 5-gallon pail (limit 2).
The rebates started in March and went through May, then, in August through October.
It makes the cost of the Delvac 1 much more reasonable.
Re: Best oil for old 12v Cummins, extended drain??? [Re: NVRENUFF] #4289822
12/31/16 03:01 PM
12/31/16 03:01 PM
Conroe, TX
NVRENUFF Offline OP
NVRENUFF  Offline OP
Conroe, TX
Thanks for the info. My 05' LLY DMAX has 340k running plain Rotella 15/40 at 12k OCI and it's never had even a slight oil leak. Just the dmax is a cleaner running motor, the old industrial flat tappet Cummins is a different beast altogether.
I'll keep an eye out for the rebates and use them when they're available again. I'll do one 10k OCI and have it sampled, then decide from there what's best.
Re: Best oil for old 12v Cummins, extended drain??? [Re: NVRENUFF] #4290488
01/01/17 02:35 PM
01/01/17 02:35 PM
Washington State (East)
Blaze Offline
Blaze  Offline
I ran my 12v on John Deere 15-40w.
Re: Best oil for old 12v Cummins, extended drain??? [Re: Ramblejam] #4290521
01/01/17 03:15 PM
01/01/17 03:15 PM
Michigan
A_Harman Offline
A_Harman  Offline
Michigan
Originally Posted By: Ramblejam
P.S. -
M1 filter
Yep, dump the M1 filter, and use Fleetguard Stratapores.
1985 Z51 Corvette track car
2002 Camaro Z28 LS1/6-speed
2001 Dodge Ram 2500 diesel
1972 GMC 1500 shortbed project truck
Re: Best oil for old 12v Cummins, extended drain??? [Re: NVRENUFF] #4290524
01/01/17 03:19 PM
01/01/17 03:19 PM
Michigan
A_Harman Offline
A_Harman  Offline
Michigan
The high load valvesprings on your built 12-valve would definitely make it a candidate for a CI4+ 15w40 oil like Valvoline Premium Blue Classic, or Mobil Delvac MX (if you can still get them). I wouldn't trust modern low-SAPS oils to protect the slider followers in an application like that. Or supplement the modern oils with Redline or ZDDPlus additives.
The stock 12-valve would also be fine on VPBC.
Re: Best oil for old 12v Cummins, extended drain??? [Re: A_Harman] #4290564
01/01/17 04:14 PM
01/01/17 04:14 PM
Schafflund, Germany
Extreme-Duty Offline
Schafflund, Germany
Don't let the newly formed "Pro ACEA E6 & 800 PPM P is the way to go in HDEO" group read this! I am still buying Delvac 1 CI-4+ over here, btw.
Been using EVER-SEEZ and Neverseal on all my stuff - I got it for free!
Re: Best oil for old 12v Cummins, extended drain??? [Re: Extreme-Duty] #4290641
01/01/17 06:12 PM
01/01/17 06:12 PM
Kentucky
Ramblejam Offline
Ramblejam  Offline
Kentucky
Man, I bet you'd hate to see CI-4+ vs. CK-4 comparative wear testing. In other words, welcome to 2017...oils have come a long way with a different approach to wear reduction:
Re: Best oil for old 12v Cummins, extended drain??? [Re: Extreme-Duty] #4290834
01/01/17 10:11 PM
01/01/17 10:11 PM
Regina, Saskatchewan, Canada
Garak Offline
Garak  Offline
You're lucky you weren't here. That stuff was gone here within weeks of the CJ-4 rollout. wink
Plain, simple Garak.
2008 Infiniti G37 - Shell ROTELLA T6 Multi-Vehicle 5w-30, NAPA Gold 7356
Re: Best oil for old 12v Cummins, extended drain??? [Re: NVRENUFF] #4291005
01/02/17 08:15 AM
01/02/17 08:15 AM
Fort Lauderdale, FL
DoubleWasp Online content
DoubleWasp  Online Content
Fort Lauderdale, FL
I have two clients who routinely squeeze 10,000 hours out of some very heavily used Cummins QSB 5.9 engines using Amsoil 12 TBN 15w40.
At first glance you might think it an irrelevant comparison, but consider that marine 5.9's are turned up quite a bit from a land 5.9's and also see a lot of idle time.
Re: Best oil for old 12v Cummins, extended drain??? [Re: DoubleWasp] #4291683
01/02/17 09:22 PM
01/02/17 09:22 PM
Conroe, TX
NVRENUFF Offline OP
NVRENUFF  Offline OP
Conroe, TX
My Passat TDI is the only diesel I've ever had and not turned up, yet. Lol
My idle time is excessive. For instance my duramax had just over 19,000hrs on the motor when it hit 300k miles. Work trucks idle from 3hrs to 3 days at a time depending on the job I'm on. I'm abusive. Lol
