So, got the 09' Camry with 111,xxx miles on it. Says 5w20 or 0w20 to use. I'm leaning towards M1 0w20 or Valvoline Maxlife synthetic 0w20 or possibly 5w20 Maxlife blend. Will go 6,000 and go from there
I'd use a 5w30 myself. 6000miles is right in the middle of a good HM oil and Syn. If you usually change it early, rarely hit 6k, then use Maxlife or another good HM oil. If you usually go over the 6k mark then a syn will work fine.
Make sure to spray out the PCV Valve, PCV lines, and throttle body with carb cleaner. Many do not do this and after 100k+ it will help a bit.
My kids 2008 Scion Tc has the same oil recommendation. Got car with 31k on it and put in 0w20. It used more oil on a 5k oil change than any car I owned. Used some T6 5w40 and Castrol 0w40 and got less oil loss. I guess you will have to watch and see if you have any oil consumption if you use 0w20.
M1 0W20 AFE. These engines aren't hard on oil, but just have the clogged oil return ports. I personally would use the 0W30 variant instead if I could find it. Castrol Edge would be nice as well. Supposedly Titanium prevents sludge build up, which COULD help prevent the oil return ports from clogging further more if those claims prove true.
Congrats on the car Car51! Surprised nobody mentioned the TGMO 0w20 already; I know it was a big deal a year or so ago. That's what's in our Camry, and I'll probably keep using it.
BTW, I pretty much know where you took that picture, lol.
