So one of our guys drives a 2011 RAM 1500. It has the traditional halogen non-projector bi-bulb housings (one bulb for high/low, one for turn/marker) and I was told yesterday that the lights are simply awful. Apparently he googled the issue and he is not alone in that opinion. So, looking at options on improving the lights without going to something illegal/offensive (like HID retrofit). Somebody suggested a direct-fit LED replacement with the LED's in the same position as the light kernel on the halogen bulb. Another simply suggested higher output bulbs. My original thought was a higher trim level housing, hopefully in a projector, but it does not appear such a beast exists unless I'm looking in the wrong spot.
From my understanding, these headlamps are both objectively and subjectively poor. That is, reports from the field are accurate -- they're genuinely lousy lamps. Further, the base model version with a single bulb (H13) offers you no real upgrade options. The H13 bulb is a poor one to begin with. Fortunately, these bulbs are rarely used anymore, but some applications still use them. We had this bulb in our 2007 Chrysler T&C, and there really isn't much you can do with it. The upgrade bulbs offer a slim improvement, but not much.
I do think there are two equipment upgrades you could make, though. His current housings are single-segment, where one bulb is used for the high and low beam. Also offered that year on higher trims was a dual-segment housing, which used an H11 for the low beam and an HB3 for the high beam. This would offer much better beam focus on both the high and the low beam, and he'd likely be able to see better. I understand these housings still aren't good performers, but they could be better than what he has.
Another option is the projector setup offered in later model years. I don't personally care for these, either. If they're like other Mopar products of the era, they use an HIR2 bulb in the projector and there's a movable shutter for high beam, not unlike an HID projector. Problem is, it's NOT HID, and it's only a halogen source, so I don't think it works well in practice. In fact, the IIHS headlamp testing bears that out.
http://www.iihs.org/iihs/ratings/vehicle/v/ram/1500-crew-cab-pickup/2016
This is the same generation, I think, as the 2011 Ram 1500. According to their testing, the halogen reflector lamps performed similarly to the halogen projectors, but the projectors created excessive glare.
My personal plan would probably be to upgrade to the dual-segment halogen reflector housings. I don't know if they make conversion wiring harnesses for H13-to-H11/HB3 lamps or not. If he doesn't want to go to that trouble, there's not much he can do. I'm glad to know he's not thinking about HID or LED. They will NOT be good in this application.
