These look like a very simple pig iron caliper, single piston, no E brake mechanism. I suspect corrosion of the slide pins or the piston due to either a rubber seal cut during assembly or poor assembly lubricant both are common with rebuilds, possibly corrosion from moisture in the system. Remove the caliper and inspect it before doing anything it might just need new pins, pin seals or just lube.
With these calipers reman is okay, there isn't much they can do to bugger them up and there is no need to pay the long dollar either for aftermarket remans (at almost $190ea its a bit of a ripoff but there are a few things you can do to improve remans before installing them on the vehicle.
First check the boot around the piston, any damage automatically disqualifies the caliper. Remove the bracket if it comes with one and disassemble its rubber parts and pins, remove the inlet bolt and bleed screw.
Plug the pin holes, fluid inlet and bleeder hole with a rubber stopper from any hardware store, wipe the whole thing down a couple of times with alcohol and dry it and mask off the piston seal.
Put 3 light coats of rattle can self etching primer on the caliper and bracket, this stuff really helps keep corrosion away over paint alone, topcoat with any high temp rattle can.
Check the pins and boots, the pins must be clean and corrosion free and look for obvious damage to the rubber like a cut, the boots should seal when squeezed between the fingers.
Clean out the pin holes in the bracket with a long Q Tip, relube and put a smear some on the pins, make sure the boots are on both the bracket and pins not just pushed up against.
I use CRC brake grease and Syl Glide, both work well and dont dry out like some of the ceramic lubes. Rock Auto has a pair of Nastra remans for $54ex, they were a good brand years ago but I haven't used them in years but they are probably not going to any worse than the others.
Links to the products I use, all these can be had at most parts stores.
https://www.amazon.com/CRC-Brake-Caliper-Synthetic-Grease/dp/B000M8IF1Q
https://www.amazon.com/AGS-SG8-Lubricant/dp/B000KXLR5E
https://www.amazon.com/Dupli-Color-DAP16...+etching+primer
