115 registered members (97K15004WD, 53' Stude, 2010Civic, 2oldtommy, Aichiguy, 14 invisible),
1,798
guests, and 22
spiders. |
Key:
Admin,
Global Mod,
Mod
Topics298,642
Posts5,139,719
Members70,113
Most Online3,589 Nov 2nd, 2019
Re: Dealer rant
[Re: Bud]
#4265591
12/04/16 10:50 AM
funflyer
Posts: 787 |
Unless it's warranty work, I avoid the dealer at all costs. But, but, but, but, they're ASE certified, which means they passed a test and washed cars, or changed oil for two years.  I do the same as you, I avoid them like the plague.
2016 Prius 1.8L 2001 Tacoma 2.4L 1966 GTO 6.5L 2015 Cub Cadet Honda CT70 (X6)
Re: Dealer rant
[Re: funflyer]
#4265607
12/04/16 11:12 AM
4WD
Posts: 10,917 |
Just depends - I steer wide of big city dealers (buy from them only) - but our small town GM dealer has had the same techs for many years - and a service manager from that same concrete floor - and if it is technically up there in scope... OK After my near miss - tire rotation is done by me or one of two places I can still watch them work ...
Re: Dealer rant
[Re: Doog]
#4265660
12/04/16 12:07 PM
totegoat
Posts: 1,380 |
Toyota dealer rotated tires 3,500 miles ago. I'll check if they are tight.
Re: Dealer rant
[Re: Doog]
#4266080
12/04/16 06:49 PM
zzyzzx
Posts: 5,046 |
Re: Dealer rant
[Re: zzyzzx]
#4266085
12/04/16 06:54 PM
OVERKILL
Posts: 40,746 |
Generally, a nut that has a chrome "sleeve" over top of it making it actually two pieces.
2019 RAM 1500 Sport - Mobil 1 EP 0w-20, FRAM Ultra 2020 Grand Cherokee SRT - Ravenol SSL 0w-40, FRAM Ultra
Re: Dealer rant
[Re: eljefino]
#4266478
12/05/16 07:29 AM
gathermewool
Posts: 7,404 |
Your torque wrench may not be accurate to 10 ft-lbs (it's ft-lbs, not ft/lbs.)
Did you actually check at 10 ft-lbs and note movement or are you guessing, because you got movement when you checked at normal torque spec? If the latter, how much movement did you note? Did you read the post before responding to it? I'm confused; did I miss something? He said he took his torque wrench and found three loose. My question was, in other words: 1. Did OP check with his torque wrench set at normal spec (e.g., something like 85 ft-lbs) and, as he checked them tight, noticed three of them actually rotated excessively before reaching the final torque value?; OR 2. Did OP check with his torque wrench set initially to a low torque value, <= 10 ft-lbs, and noticed that three weren't even at this torque value, because they rotated? Plot twist, maybe he used a beam wrench, not a clicker!  Right, he could have noted movement before the beam indicated 10 ft-lbs. Even if below the cal curve of the wrench, movement below 10 most likely indicates loose.
14 Forester XT Touring FA20DIT (Cobb Stage 1) Castrol Magnatec 5W-30 D1G2 + FU filter (72,320mi, 8/24/19) 15 Legacy Premium FB25 Magnatec 5W-20 + FU filter (47,300mi, 5/11/19)
Re: Dealer rant
[Re: Doog]
#4266493
12/05/16 07:56 AM
KrisZ
Posts: 9,155 |
Guys, check your nuts! And don't be shy to get a second pair of eyes and hands on them
2015 Grand Caravan 3.6L - 31k miles. 2006 Mazda 3 2.0L - 171k miles
Re: Dealer rant
[Re: dlundblad]
#4266620
12/05/16 10:32 AM
cptbarkey
Posts: 3,016 |
Rather than a childish rant about it on a discussion forum, why not call the service department and discuss it with them first? Enlighten all of BITOG on how OP's rant was CHILDISH. If you notice, some folks actually gave advice and as others said, it can be a lesson learned for the safety of others. Say an old couple or busy single mom or a not so mechanically inclined individual went in for the same service, but didn't know to check the torque because they rightfully assumed all was well. Before spewing whatever ignorant thought comes to your head, perhaps you should simply think first? You dont speak for me sir, I also think it is childish and bad form, but then again 1/3 of most posts in the off topic forum fit this definition.
Re: Dealer rant
[Re: Doog]
#4266822
12/05/16 01:10 PM
sleddriver
Posts: 4,838 |
Wise of you to check. Many don't, hop in the car with family for a trip, then get stuck on the side of the road, plans all shot to h$ll.
Don't forget the spare....
1998 Volvo V70 T5 228,880 mi. Original Owner. M1 10W-30 HM "It's never a mistake to buy tools, defined broadly. They're not a cost, they're an investment." - J.B. Peterson
Re: Dealer rant
[Re: Doog]
#4266829
12/05/16 01:18 PM
oilpsi2high
Posts: 1,862 |
I took my car to a Valvoline for a state inspection and was amazed to see that the kid working there used a torque wrench to install my tire after checking the brakes. I wanted to give him a tip for that.
Re: Dealer rant
[Re: OVERKILL]
#4266835
12/05/16 01:22 PM
Lolvoguy
Posts: 3,449 |
Generally, a nut that has a chrome "sleeve" over top of it making it actually two pieces. yeah, I have those too. Never had a car with them before. Cant say I'm a fan.
06 Lexus IS350- Wife 88 BMW 325is- Mistress Say "no" to Turbo!
Re: Dealer rant
[Re: OVERKILL]
#4266839
12/05/16 01:32 PM
aquariuscsm
Posts: 20,704 |
Generally, a nut that has a chrome "sleeve" over top of it making it actually two pieces. My Trofeo had these and the chrome sleeves eventually all fell off :p
1996 Nissan 300ZX 5-speed,Arctic Pearl(#175 of 300) Quaker State Ultimate Durability 10W30 2012 Honda Accord Coupe EX-L 2.4,auto,San Marino Red Quaker State Ultimate Durability 0W20
Re: Dealer rant
[Re: Bud]
#4266862
12/05/16 01:45 PM
Nickdfresh
Posts: 6,156 |
Unless it's warranty work, I avoid the dealer at all costs. +1
Re: Dealer rant
[Re: Lolvoguy]
#4266867
12/05/16 01:46 PM
oilpsi2high
Posts: 1,862 |
Generally, a nut that has a chrome "sleeve" over top of it making it actually two pieces. yeah, I have those too. Never had a car with them before. Cant say I'm a fan. I also have them. The OEM ones are fine, but the cheap replacements suck and the chrome piece falls off eventually.
Re: Dealer rant
[Re: gathermewool]
#4267090
12/05/16 05:42 PM
Doog
OP
OP
Posts: 6,170 |
Did you actually check at 10 ft-lbs and note movement or are you guessing, because you got movement when you checked at normal torque spec? If the latter, how much movement did you note? One nut took 1.5 turns, the other took about 1/5.
