As with other new ST anecdotes posted, for ~$2.85 looks to be a very serviceable filter. For a ~5k mile conventional oil oci, I'd have no problem using one. Same as the popular ST9688 and 3614, this one also uses a separate dome bypass.
Filter cutter looks to be identical to the one sold at Summit and Jegs. I own the Summit and biggest complaint is with ~3" or less diameter filters, filter base seam area hits the cross bar, not guide wheels. But it still works just not smoothly.
Thanks for c&p.
