Which car to buy?
by jrcowboys. 12/12/18 04:55 PM
New Tire Cracking
by robd. 12/12/18 04:43 PM
SAR B6P - Thoughts?
by 28oz. 12/12/18 03:59 PM
Time to sell the 1-ton Dually
by 02SE. 12/12/18 03:55 PM
Shell Rotella Grease
by WMW0505. 12/12/18 02:27 PM
Need to add attic ladder in stairwell
by Klutch9. 12/12/18 12:51 PM
Mystik JT-8 15w40, 2015 RAM EcoDiesel, 4,995 mi
by SavagePatch. 12/12/18 12:45 PM
Fram Tough Guard Air Filters at Rock Auto
by Snagglefoot. 12/12/18 12:42 PM
Electrical contact cleaner
by CELICA_XX. 12/12/18 12:32 PM
5w-30 in 277k mile chevy 350 tbi
by dogememe. 12/12/18 12:22 PM
voltage test for coolant condition
by NissanMaxima. 12/12/18 12:17 PM
paying Premiun for the name(infiniti/nissan
by 2008wrx. 12/12/18 11:25 AM
POE oil (R-410a)
by WyrTwister. 12/12/18 09:44 AM
Any Volvo Owners, need some help!
by LazyDog. 12/12/18 09:34 AM
NOACK & Sheer
by WyrTwister. 12/12/18 09:34 AM
Rotary help. 2010 series 2 RX8
by TinyVoices. 12/12/18 08:32 AM
Can you mathematically estimate top speed?
by KCJeep. 12/12/18 08:06 AM
2019 GM 6.2 AFM
by XL1200RFan. 12/12/18 07:32 AM
jefe_de_estado, CM613, Geardaddies, 01ws666, ariefnrst
66660 Registered Users
108 registered members (ad244, 28oz, 97K15004WD, 64bawagon, 53' Stude, AdditiveOCD, 14 invisible), 1,862 guests, and 39 spiders.
Topics294,990
Posts4,925,558
Members66,660
Most Online2,553
Oct 27th, 2018
Page 1 of 4 1 2 3 4
Cleaning sludgy nissan VQ #4252889
11/19/16 12:38 PM
11/19/16 12:38 PM
PA
MarcS Offline OP
MarcS  Offline OP
PA
So, here is the story: purhaced a car off lease with about 34k on the clock. Things appeared ok at purchace (clean dipstick, no crud visible from the oil fill. Shortly after purchace it started occasionally blowing a cloud of smoke at startup. Dealership ran a compression test and all was good. Techs were baffled and generally unhelpful. I managed to figure out that the PCV passage in one of the valve covers was gunky and not draining well. As oil mist co densed it was retaining a pool of oil that was getting sucked into the PCV on startup. Blasted it out, cleaned the pcv, no more smoke, no more oil consumption. Was thrilled ot wasn'trings or valves but suspected the former lessee was less than dilligent about oil changes. Switched to M1 synthetic figuring it will slowly clean and all was well.
Fast forward another 25k mi and i get a check engine light for low oil pressure and camshaft timing. Dealerhip finds a blown oil gallery gasket (not uncommon) and goes to replace under warranty. Turns out the engine is kinda gross inside an and the gallery is sludgy, as is the cam actuator.
I think my slow cleaning with M1 is starting to break things loose. Dealership has replaced the front timing cover, timing chain and tensioners and one of the VVT actuators that was failing. They also cleaned up that area of the engine and the oil pan and pickup.
I'm left with a connundrum. Do i keep slow cleaning and risk more crud breaking lose elsewhere in the engine or do a hail mary with a fast flush to try and clear out as much as i can, then continue with short OCIs?
Re: Cleaning sludgy nissan VQ [Re: MarcS] #4252895
11/19/16 12:52 PM
11/19/16 12:52 PM
Waterloo, ON
Bluestream Offline
Bluestream  Offline
Waterloo, ON
Slow and steady Son, that will get you where you want to go.
2000 VW Beetle 1.8T M5
2006 Pathfinder 4X4
1991 BMW 735iL
"A fool and his money are soon parted" - Thomas Tusser
Re: Cleaning sludgy nissan VQ [Re: MarcS] #4252898
11/19/16 12:58 PM
11/19/16 12:58 PM
OH
SatinSilver Offline
SatinSilver  Offline
OH
I think I'd go with some PYB or some Maxlife syn-blend. A full syn in a possibly neglected engine, no thank you, way too risky for me.
Re: Cleaning sludgy nissan VQ [Re: SatinSilver] #4252929
11/19/16 01:40 PM
11/19/16 01:40 PM
The Northeast
mclasser Online content
mclasser  Online Content
The Northeast
+1
2018 Hyundai Elantra VE -- 6K
2013 Honda Pilot EX-L 4WD -- 57K
2002 Honda Accord EX-L -- 212K
Re: Cleaning sludgy nissan VQ [Re: mclasser] #4252943
11/19/16 02:18 PM
11/19/16 02:18 PM
PA
MarcS Offline OP
MarcS  Offline OP
PA
I think the M1 got me to this point by breaking up some of the sludge. I wouldnt call it possibly neglected either. Despite a half dozen M1 changes in the last year, i got a look at the timing cover and, while I've seen worse, there was definitely a good amount of varnish and some sludge in the less oil washed areas. No hard deposits evident, just tar-like gunk
On the bright side, the entire timing cover and associated galleries are brand new, as are the vvt actuators. The front cover, oil pan and pickup have been manually cleaned. My only concern is that deposits elsewhere in the engine will break loose down the line and again plug one of the billion tiny oil passages in the complicated valvetrain and i wasnt sure if a flush would get it out or just loosen it up more making things even more precarious.
Re: Cleaning sludgy nissan VQ [Re: MarcS] #4252954
11/19/16 02:33 PM
11/19/16 02:33 PM
Virginia
bbhero Offline
bbhero  Offline
Virginia
The VQ motors are not great long run interval oil change motors. With only a shade under 5 qt capacity they don't have much in terms of extra capacity to help keep oil temps down and not as much containment holding capacity either. This is compared to other motors that have 6.5 qts plus. I hope this all gets a whole lot better for you.
Nissan Altima 3.5 Coupe
Mobil Super 5w30 Wix 57356
"Treat your family like your friends and treat your friends like your family."
Re: Cleaning sludgy nissan VQ [Re: bbhero] #4252956
11/19/16 02:39 PM
11/19/16 02:39 PM
PA
MarcS Offline OP
MarcS  Offline OP
PA
I'm aware. 3750mi recommended oil changes. The heat and friction from the VVEL system and a 7500rpm redline also shears oil like mad, which is why i was using synthetic and would like to continue if it is safe to do so.
I don't think the engine design was the problen as much as a lessee who didn't see the point of changing oil on a "rental car"
Re: Cleaning sludgy nissan VQ [Re: MarcS] #4252960
11/19/16 02:49 PM
11/19/16 02:49 PM
big sky country, Canada
vitez Offline
vitez  Offline
I've used Amsoil Engine and Transmission flush in the last 5 used vehicles I've bought and never had any engine issues.
http://www.amsoil.com/shop/by-product/ot...?code=FLSHCN-EA
If your engine still exhibits some sludge after 25K of M1, I would do an engine flush. The Amsoil product is a detergent, not a solvent, and extremely unlikely to break off big chunks of anything. Besides, by your description you don't have big chunks of anything anyway!
I have CDO. It's like OCD except in alphabetical order like it should be.
Re: Cleaning sludgy nissan VQ [Re: Bluestream] #4252963
11/19/16 02:54 PM
11/19/16 02:54 PM
Outer Banks, NC
NormanBuntz Offline
NormanBuntz  Offline
Outer Banks, NC
Welcome to the board.
+1 on the above and the recommendation for PYB or even Quaker State. You don't mention the year and model. In my wife's M35 I used Kendall synthetic blend for the first 65K miles. I have stuck to oil changes of 4,500 miles. For the last 30K miles I've used my own blend of 40% Quaker State Ultimate 5w-30 and QS conventional, and the engine appears clean and runs quietly. When I changed the PCV valve at 93K miles, it was quite clean.
To clean you may also want to try Pennzoil Gold 5w-30 at Walmart for about $17 a jug. I now like the Fram Ultra filters for this engine, or the Fram Pro Synthetic Series you can find on eBay.
2017 Honda Odyssey SE, 16K
2013 Honda Accord LX, 58K
2007 Honda Ridgeline RTS, 88K
2007 Infiniti M35, 107K
Re: Cleaning sludgy nissan VQ [Re: MarcS] #4252975
11/19/16 03:04 PM
11/19/16 03:04 PM
Chicago, IL
tomcat27 Offline
tomcat27  Offline
Chicago, IL
I would just continue using synthetic with reasonable OCI's. I've seen more than a few examples of leased cars where the oil was never changed. When we recently bought an off-lease vehicle, I pulled the valve cover and inspected before we finalized the deal. (it was spotless inside) Of course, I have friends who don't change oil in the cars they have purchased, so its not limited to leases, but likely much more prevalent.
2019 Cherokee, 2018 Jetta, 2014 Sentra, 1995 Escort, 1970 Cougar, 2013 XT250, 2010 Vstar, 2014 CTX1300
Re: Cleaning sludgy nissan VQ [Re: vitez] #4252980
11/19/16 03:15 PM
11/19/16 03:15 PM
PA
MarcS Offline OP
MarcS  Offline OP
PA
Well, a picture is worth a thousand words. This is the engine with the front cover off prior to the rear timing cover and components getting replaced
Back of front cover (since cleaned)
The most baked on stuff found was still tarry, not coked
VVT actuator (since replaced)
I'm sure you can extrapolate as to what might remain elsewhere in the engine.
Re: Cleaning sludgy nissan VQ [Re: vitez] #4252981
11/19/16 03:18 PM
11/19/16 03:18 PM
England
UltrafanUK Offline
UltrafanUK  Offline
England
I agree, using a flush designed for use at idle would get the block clean far faster than just doing short OCI's with a good cleaner oil.
Shell Ultra 0 or 5w40 or Liqui Moly 5w40 plus Ceratec every long OCI.
LM idle flush every 100K km.
Re: Cleaning sludgy nissan VQ [Re: tomcat27] #4252982
11/19/16 03:19 PM
11/19/16 03:19 PM
PA
MarcS Offline OP
MarcS  Offline OP
PA
Yeah, I was complacent since it was such a young car and the parts i could see through the oil fill werent even varnished. I suppose a shady car dealer could have blasted anything visible away with carb cleaner and put clean oil in.
Re: Cleaning sludgy nissan VQ [Re: UltrafanUK] #4252983
11/19/16 03:22 PM
11/19/16 03:22 PM
PA
MarcS Offline OP
MarcS  Offline OP
PA
Just concerned something like that will send any remaining sludge right back into the problem areas that were just cleaned or replaced. Most of them have warnings abot using on heavily slidged engines and I dont know what they consider "heavily sludged"
Re: Cleaning sludgy nissan VQ [Re: MarcS] #4252987
11/19/16 03:29 PM
11/19/16 03:29 PM
Cincinnati, OH, USA
bullwinkle Offline
bullwinkle  Offline
Cincinnati, OH, USA
I'd go PYB with 3K OCIs-any flush you run is going to just jam it up again.
06 Ram 3500 CTD 4X4(FG Venturi), 93 GMC C3500 6.2, 89 F-450 7.3, 98 XJ 4.0(XG8A), 05 xB(XG3600), 18 Transit 3.7, 03 Merc Grand Marquis 4.6 2V(XG2)
Page 1 of 4 1 2 3 4
