KTM 1190 Adventure oil viscosity?
by vfrkent - 04/03/20 11:42 PM
2011 Kia 2.7L Theta Hav. Pro DS
by twouvakind - 04/03/20 10:40 PM
Replacing Rusted Fuel Lines
by 92saturnsl2 - 04/03/20 10:35 PM
(3) 5-quart + Fixd ODB-II reader for $40.50+tax
by wkcars - 04/03/20 09:57 PM
Tesla Crushing It
by JeffKeryk - 04/03/20 08:42 PM
Pacific Valley in Big Sur with the E46
by SLO_Town - 04/03/20 08:33 PM
I drove a Delta pilot to the airport today
by 14Accent - 04/03/20 07:41 PM
ALUMINUM BLACK™ metal finish touch-up pen
by vavavroom - 04/03/20 07:28 PM
Strut leak
by ford46guy - 04/03/20 06:30 PM
Orifice tube backwards, now can’t reach it
by gallydif - 04/03/20 06:14 PM
Bone creeper?
by JHZR2 - 04/03/20 05:58 PM
Wrangler TJ Engine Oil
by TJim - 04/03/20 04:53 PM
Virgin XG3600 cut open
by bullwinkle - 04/03/20 04:30 PM
Windows Update and Shutdown update confusion
by simple_gifts - 04/03/20 04:29 PM
Mildew Smell in AC System
by painfx - 04/03/20 04:17 PM
M1-113A CUT OPEN
by 53' Stude - 04/03/20 03:56 PM
MC FL500S 7,000 miles CUT OPEN
by 53' Stude - 04/03/20 03:43 PM
USS Theodore Roosevelt
by BMWTurboDzl - 04/03/20 03:42 PM
2020 Subaru Forester Base
by wagsrk08 - 04/03/20 03:41 PM
New Rislone Hy-per Fuel Product?
by Jackson_Slugger - 04/03/20 03:38 PM
Peacock, Agauth12, PatGN, Fjordman95, TJim
71086 Registered Users
69 registered members (Bill_W, 87sammy, bbhero, 2010Civic, AZjeff, Ag76, 12 invisible), 1,618 guests, and 19 spiders.
Topics303,554
Posts5,237,337
Members71,086
2008 accord 2.4 timing chain tensioner cover leak #4252000 11/18/16 10:10 AM
B
Brybo86 Offline OP
B
Background on car. Now has 127,000miles
Uses about 1 quart every 7500 miles since new. Especially with high speed driving.
I noticed a very small amount of oil on lower right side of engine.
Not enough to get any drops on the driveway.
But obviously enough to get on the side of the engine/timing cover.
The only thing I can think of other than coincidence is that when the oil pump was replaced under warranty at 50,000 miles they didn't put enough hondabond on the cover?
there are 3 10mm bolts holding it on.
Can I just take the cover off, clean and reapply the FIPG/Hondabond?
Does anyone know if the oil level is at or above the inspection cover? Should I drain oil first?
Thanks in advance!
12 Honda Odyssey 112k
09 Kymco Super8
08 Honda Accord 2.4L 164k
01 Kymco People 50
95 Yamaha Jog
Re: 2008 accord 2.4 timing chain tensioner cover leak [Re: Brybo86] #4252017 11/18/16 10:27 AM
J
Jimzz Offline
J
Before doing that I would clean the area real well and then go for about a 3 mile drive. Then look at it again. Could be a crank seal slinging as well.
If it is that then yea just remove and seal properly. Make sure to use some good stuff at least Ultra level or better RTV.
yup
Re: 2008 accord 2.4 timing chain tensioner cover leak [Re: Brybo86] #4252041 11/18/16 10:50 AM
L
LeakySeals Offline
L
sometimes you can just crank the bolts down a bit, goes away
06 Escalade 6.0L LQ9 AWD 170k M1 5w30
03 Maxima 3.5L 170k Maxlife HM 10w30
05 Malibu Classic 2.2 111k M1 5w30
06 Altima 2.5L 167k unk
Re: 2008 accord 2.4 timing chain tensioner cover leak [Re: LeakySeals] #4252068 11/18/16 11:28 AM
H
HerrStig Offline
H
Don't use a breaker bar smile.
Re: 2008 accord 2.4 timing chain tensioner cover leak [Re: Brybo86] #5379011 03/17/20 08:17 PM
B
Brybo86 Offline OP
B
Lemme revive this old thread by saying I finally got around to resealing the cover.
I think the chump at dealer who changed the VTC awhile ago did a really sloppy job on the reseal.
You can see the corner of the cover that is behind the flywheel never got the original factory RTV completely removed, just kinda slathered the new on top of the old.
I understand why.
It is a major pain in the bum to get behind the flywheel. It is so tight back there and I have relatively small hands.
I used a small screwdriver and some Emery cloth/ sandpaper to rub behind the flywheel. Then cleaned with brake cleaner.
Honestly if I were to do this again I would take off the belt and remove the crank pulley.
09 Kymco Super8
01 Kymco People 50
95 Yamaha Jog
Re: 2008 accord 2.4 timing chain tensioner cover leak [Re: Brybo86] #5379308 03/18/20 08:05 AM
W
WyrTwister Offline
W
Is it holding ?
Wyr
God bless
Re: 2008 accord 2.4 timing chain tensioner cover leak [Re: Brybo86] #5379654 03/18/20 03:35 PM
T
Tundragod Offline
T
Good job, it must've been a [censored] tackling that job.
12 Highlander limited, 08 Accord EXL 4, 04 MDX Tour, 02 CRV EX, 1995 Virago.
Re: 2008 accord 2.4 timing chain tensioner cover leak [Re: WyrTwister] #5380212 03/19/20 09:57 AM
B
Brybo86 Offline OP
B
Originally Posted by WyrTwister
Is it holding ?
Temp was about 40-45 F and raining tuesday to wedneday in Chicago.
The engine was warmish when installed
It sat for about 20 hours before being driven.
Wife drove it to the grocery store yesterday, so far so good.
09 Kymco Super8
01 Kymco People 50
95 Yamaha Jog
