Heavy Snow Predicted for Northeast Sat/Sun
by Donald. 01/17/19 08:34 PM
Pennzoil Ultra Plat 5w30 1.4L T Chevy Cruze 10k
by SubieBlue. 01/17/19 08:03 PM
Coated rotors
by supton. 01/17/19 07:51 PM
Good samaritan
by JLTD. 01/17/19 07:15 PM
Doing suspension work. Need alignment?
by HawkeyeScott. 01/17/19 05:45 PM
100mg CBD Cannabis Gel
by Al. 01/17/19 05:36 PM
Electric Car "Green Test"
by redbone3. 01/17/19 05:06 PM
Want to try a uoa
by Dylan1303. 01/17/19 04:56 PM
Happy Birthday, Betty White!
by eljefino. 01/17/19 04:20 PM
Fram Ultra for Ecoboost 2.7
by Purpfox. 01/17/19 04:10 PM
Idle Speed / 1998 Olds 88
by Mark72. 01/17/19 03:28 PM
Heat blanket for your oil filter!
by MrWideTires. 01/17/19 03:24 PM
Proper oil viscosities.
by Bullwinkle007. 01/17/19 03:20 PM
44$ for 5 gals of home heating oil treatment!
by Audios. 01/17/19 03:05 PM
Good job Hyundai!!!
by Andy636. 01/17/19 02:43 PM
PP 0W-20 vs PP HM 0W-20 - Difference in VI
by The Critic. 01/17/19 02:34 PM
Dickerson888, Frisky, polarisman340, jfradella, Bigyetti83
66964 Registered Users
124 registered members (Aero540T, 4WD, 69Torino, AdditiveOCD, 2015_PSD, 9 invisible), 1,710 guests, and 49 spiders.
Topics296,750
Posts4,958,214
Members66,964
Most Online2,577
Jan 14th, 2019
Page 1 of 3 1 2 3
Schaeffer 9000 5w40 in Detroit 60 #4250974
11/16/16 08:47 PM
11/16/16 08:47 PM
Central Iowa
TiredTrucker Offline OP
Central Iowa
Had run a Schaeffer 15w40 blend initially with this motor. A year ago, moved over to a Schaeffer 10w30 blend to see how it did. Last oil change, moved to Schaeffer 9000 5w40 full syn. Here is the sample on the 5w40. Newest sample at top of the listings, with the previous 3 results on 10w30 following. 617260 miles on the engine after a factory reman. 20749 miles on this oil.
Freedom is not about having the choice to do what you want, but the choice to do what you ought.
Re: Schaeffer 9000 5w40 in Detroit 60 [Re: TiredTrucker] #4250980
11/16/16 08:56 PM
11/16/16 08:56 PM
Idaho
CT8 Offline
CT8  Offline
Idaho
Did the seat of the pants dyno tell you anything? Seems the Iron is a bit higher and the Lead lower what ever that may mean.
2015 Ford F150 2.7
2018 Ford F350 6.2
Re: Schaeffer 9000 5w40 in Detroit 60 [Re: TiredTrucker] #4250987
11/16/16 09:06 PM
11/16/16 09:06 PM
Kalifornia Kollective
BrocLuno Offline
BrocLuno  Offline
Lower lead may mean less bearing metal in circulation ...
The increase in iron might mean liner wear...
Not saying these are what's happening, just could-be's ... Or, could be flushing stuff that was already there, but not mobilized by the previous oil ...
In any case it all looks real good smile
Re: Schaeffer 9000 5w40 in Detroit 60 [Re: TiredTrucker] #4250989
11/16/16 09:08 PM
11/16/16 09:08 PM
Central Iowa
Central Iowa
yeah, I kinda attributed the higher FE it to the boat load of calcium that the 5w40 has in it. And I do mean a boat load. 3739 is a powerful amount of calcium in that oil. Might have cleaned things up a little and increased iron. Not worried, as the max FE allowed in 15,000 mile interval according to the 2016 Detroit Lube Manual is 200 ppm. The 31 ppm FE on this report was from almost 21,000 miles on the oil. Not bad for a motor that is now 620,000 miles into it's second life! Given the low soot level and other factors, if FE was a issue I would have guessed air compressor or bull gear before liner wear. Either way, it falls into the range of FE that it has gotten for a long time. Still very low.
Re: Schaeffer 9000 5w40 in Detroit 60 [Re: TiredTrucker] #4251061
11/16/16 10:42 PM
11/16/16 10:42 PM
NY
Rendezvous Offline
Rendezvous  Offline
NY
Did the 5w40 always have that much zinc?
Re: Schaeffer 9000 5w40 in Detroit 60 [Re: TiredTrucker] #4251085
11/16/16 11:29 PM
11/16/16 11:29 PM
Idaho
CT8 Offline
CT8  Offline
Idaho
Schaeffer's oils aren't for children !
2015 Ford F150 2.7
2018 Ford F350 6.2
Re: Schaeffer 9000 5w40 in Detroit 60 [Re: TiredTrucker] #4251134
11/17/16 04:33 AM
11/17/16 04:33 AM
Regina, Saskatchewan, Canada
Garak Offline
Garak  Offline
Did you change it, or was this an in-service sample?
Plain, simple Garak.
2008 Infiniti G37 - Shell ROTELLA T6 Multi-Vehicle 5w-30, NAPA Gold 7356
Re: Schaeffer 9000 5w40 in Detroit 60 [Re: TiredTrucker] #4251170
11/17/16 06:52 AM
11/17/16 06:52 AM
upstate NY
dustyroads Offline
dustyroads  Offline
upstate NY
Anyone looking for a high phosphorus/zinc oil? smile
2013 F150 XLT 5.0 4X4 104k miles
Edge 5W-30 / Fram 10575
Re: Schaeffer 9000 5w40 in Detroit 60 [Re: TiredTrucker] #4251173
11/17/16 06:55 AM
11/17/16 06:55 AM
NC
BigD1 Offline
BigD1  Offline
NC
That is some stout oil for sure.
I know this is off topic, but I am interested in knowing what kind of fuel mileage you are getting grossing near 80,000 pounds with no head wind? Last rig I drove years ago had the series 60 Detroit, so I am curious to know if fuel mileage has gone up since it dictates how much money is going in your pocket.
1992 Toyota Pickup--PYB 10W-30--Fram PH3614
Re: Schaeffer 9000 5w40 in Detroit 60 [Re: Garak] #4251189
11/17/16 07:13 AM
11/17/16 07:13 AM
Central Iowa
Central Iowa
I did change it. I had no pattern for how it would perform so didn't want to run it longer without some data to confirm. And it takes a week to get results back from the lab, and I can put another 3000 miles on the truck in that time frame. Will take the current fill to 25,000 and see what it looks like. Will probably change it at that time as well.
Re: Schaeffer 9000 5w40 in Detroit 60 [Re: BigD1] #4251191
11/17/16 07:16 AM
11/17/16 07:16 AM
Central Iowa
Central Iowa
Truck has averaged around 7.93 mpg for it's entire life. Best month average was around 8.65. Would be nice if that was more often. Dry van work, some light some heavy, some backroad rolling hills, some nice flat interstates. A mix.
Re: Schaeffer 9000 5w40 in Detroit 60 [Re: Rendezvous] #4251193
11/17/16 07:18 AM
11/17/16 07:18 AM
Central Iowa
Central Iowa
First run on it, so no perspective on that. Will see what the next run shows. Same batch on oil.
Re: Schaeffer 9000 5w40 in Detroit 60 [Re: TiredTrucker] #4251934
11/18/16 07:47 AM
11/18/16 07:47 AM
Garak Offline
Garak  Offline
I'm going to be that guy and bet it would last a lot longer, too.
Re: Schaeffer 9000 5w40 in Detroit 60 [Re: TiredTrucker] #4252439
11/18/16 08:33 PM
11/18/16 08:33 PM
Central Iowa
Central Iowa
One can always hope. Not looking to set some sort of OCI record, but not beyond gradually taking things out longer till my comfort level gets the best of me.
Re: Schaeffer 9000 5w40 in Detroit 60 [Re: TiredTrucker] #4258527
11/26/16 11:38 AM
11/26/16 11:38 AM
UT. USA
Dak27 Offline
Dak27  Offline
UT. USA
TT, that looks outstanding. As a matter of fact, the previous UOA's look outstanding as well.
Page 1 of 3 1 2 3
