I'm doing a little preventive maintenance on my Toyota truck, and I'm curious about alternator output. Specifically, I'm wondering what is a "proper" alternator output to maintain the surface charge on my battery?
With the motor running and all electrical accessories turned on, "Eric the Car Guy" says that a battery voltage measurement of anything that's at least .5V higher than resting battery voltage is fine and means that the alternator is working fine. In his video (Time 5:20 - https://www.youtube.com/watch?v=FTGz0PKIl84), the alternator puts out 13.16V and he thinks that's great! However, Tony Candela of CE Auto Electric Supply (https://ceautoelectricsupply.com/) says it takes a MINIMUM of 13.4 Volts to keep a surface charge on a battery. Less than that will start to discharge your battery. Time 5:19 - https://www.youtube.com/watch?v=7yTyUw-Z5o4
Who's right?
Thank you,
Ed
Who's right?
Thank you,
Ed
