Mater Mechanic Motor Oil @ True Value
by CG_BrianM. 03/20/19 01:35 PM
Some cars haven't changed much in 30 years...
by addyguy. 03/20/19 01:16 PM
Super Knock - Engineering Explained
by StevieC. 03/20/19 01:11 PM
Mobil Super Synthetic Clearance at Meijer
by Tjbouwhu. 03/20/19 12:53 PM
FYI: Costco is now stocking the 'good' Techron
by mbz321. 03/20/19 12:32 PM
Auto maintenance advice from a locksmith?
by Variant_S. 03/20/19 12:18 PM
Purolator 12 Pack L25608 $21
by hatt. 03/20/19 12:04 PM
Dealer service and franchise laws.
by BMWTurboDzl. 03/20/19 11:46 AM
Tie rod tapers
by LeakySeals. 03/20/19 11:26 AM
Quality Lug Nuts
by jcartwright99. 03/20/19 10:56 AM
More than one Reality
by beanoil. 03/20/19 10:50 AM
Reusable Oil Storage Container
by BamaE92. 03/20/19 10:37 AM
Bank 1 on an Equinox
by Washoe_Mark. 03/20/19 08:47 AM
How do you pronounce the word Vehicle?
by ZZman. 03/20/19 08:21 AM
Inline Fuel Filter
by CCI. 03/20/19 08:08 AM
Are All Douglas Tires USA Made?
by Miller88. 03/20/19 07:30 AM
Turn signal bulbs for '15 BMW?
by Benzadmiral. 03/20/19 07:02 AM
Saxman657, Maxxforce, Washoe_Mark, CG_BrianM, TBF
67565 Registered Users
120 registered members (555, 2015_PSD, albenjoseph, 97f150, 69Torino, 2012AccentSE, 17 invisible), 2,122 guests, and 62 spiders.
Topics286,156
Posts4,903,149
Members67,565
Most Online2,967
Mar 10th, 2019
Motul 300V 5W40, 5000km, 60000km ODO, Subaru BRZ #4245797
11/10/16 01:56 AM
11/10/16 01:56 AM
Outside US
Shiberu Offline OP
Shiberu  Offline OP
Outside US
Hi guys,
This is my first (ever) oil analysis with my Subaru BRZ using the Motul 300V 5W-40. Car is a daily driver (city & highway) and seeing track days every now and then.
The tech commented that silicone can be found in the oil and has potential abrasive properties, any idea if that is of major concern? It was also mentioned that the oil's flashpoint has reduced by quite a significant amount and could be due to fuel contamination, any comments on this as well?
Any further feedback on the findings would be great!
Re: Motul 300V 5W40, 5000km, 60000km ODO, Subaru BRZ [Re: Shiberu] #4245851
11/10/16 06:44 AM
11/10/16 06:44 AM
Outside US
Shiberu Offline OP
Shiberu  Offline OP
Outside US
Update: Looks like the tech updated their diagnosis
Seems like the low flash point was not of a concern after all?
Re: Motul 300V 5W40, 5000km, 60000km ODO, Subaru BRZ [Re: Shiberu] #4245874
11/10/16 08:03 AM
11/10/16 08:03 AM
Malaysia
zeng Offline
zeng  Offline
Malaysia
On the basis of assuming this sample,when new and unused, was as per PDS specs of , among others:
a) [email protected]*C of 13.6 cSt , and
b) Flash Point of 230*C,
the so called 'fuel contamination/dilution' is of no consequential negative effects in this UOA (in terms of metal wear which is well better than normal).........
IF the lab Flash Point reading of below 190*C is free of error .......
which i'm doubtful ... though i've no evidence to back up my position.
The high 22 ppm of Al and 23 ppm of Si may well indicate issues with air intake system.
However bearing in mind there is negligible or no metal wear on Pb, Sn, Ni, Cu and Cr etc ,my hunch is part or whole of 22 ppm Al is not metal wear (of engine components,excepting aluminium cyl head and block ).......
but being unwanted contaminants and/or part of additive pack, as is probably the case with 23 ppm of Si too.
Btw, I believe this used oil sample is fit for continuing service.
JMHO. blush
Re: Motul 300V 5W40, 5000km, 60000km ODO, Subaru BRZ [Re: Shiberu] #4245903
11/10/16 08:46 AM
11/10/16 08:46 AM
Brittany / Canada
Popsy Online content
Popsy  Online Content
Brittany / Canada
Silicon is an additive in this oil, at 23ppm I don't think it is anything but additive. SInce Fe is low, just double check the air intake (filter + hoses) to be safe.
Aluminium is strange, I remember these oils having aluminium in voa due to aluminium packaging, but not 22ppm.
Does this engine have aluminium bearings?
Edit: where are you from? This labs name rings a bell!
96 Barchetta, 300V 5W40 | Forfour 95, SHU 0W40
Mazda 6 2.3, M1 AFE 0W20 | Colt Ralliart, 300V 0W40
Re: Motul 300V 5W40, 5000km, 60000km ODO, Subaru BRZ [Re: Shiberu] #4245938
11/10/16 09:40 AM
11/10/16 09:40 AM
Virginia
bigt61 Offline
bigt61  Offline
Virginia
As mentioned above - make sure your air filter is tight - seal w grease if necessary. High AL reading could also come from piston skirts - especially in a high reving engine like this where piston speeds are unimaginable. Take care to make sure the oil is warmed up before you put your foot in it, especially on cold winter mornings. Track days require the oil to be at least 150F before you go max throttle. Depending on how much track time this engine sees, 22ppm may not be that bad. Race cars wear out everything fast.
92 Suburban 2500 7.4L 58k M1_0w40 5yr OCI
99 Olds Aurora 4.0L 91K M1_5w30 5yr OCI
13 Dodge Dart 2.0L 30k PP 0w20 OLM OCI
70 Camaro 5.7L 59k
Re: Motul 300V 5W40, 5000km, 60000km ODO, Subaru BRZ [Re: Shiberu] #4245940
11/10/16 09:51 AM
11/10/16 09:51 AM
Pindorama
Ohle_Manezzini Offline
Pindorama
Do you really need to use 98 octane gasoline? Fuel dilution can be from high octane fuel in a daily drive.
Re: Motul 300V 5W40, 5000km, 60000km ODO, Subaru BRZ [Re: Shiberu] #4246025
11/10/16 11:56 AM
11/10/16 11:56 AM
Brittany / Canada
Brittany / Canada
If he's from Frogland too, there's not much choice : 98 octane or 95-E10...which is IMO [censored] for such engines.
Note the price difference is not that great if you choose carefully your station smile
Re: Motul 300V 5W40, 5000km, 60000km ODO, Subaru BRZ [Re: Ohle_Manezzini] #4246468
11/10/16 10:46 PM
11/10/16 10:46 PM
Outside US
Shiberu Offline OP
Shiberu  Offline OP
Outside US
JMHO. blush
Well, I do have a aluminium intake piping and silicone copuling running on my intake laugh. I hope that is not the source of the foreign metals. I have swapped back to the stock rubber intakes to eliminate any variables when i send the next sample for another UOA.
I am not sure on the bearing materials. Will have to do some research. I am from Singapore!
For sure! That was one reason why I had a oil temp gauge hooked up. If ~22ppm looks okay, I hope the trend either reduces or stays that way.
The owners manual did call for RON98. So I'll try to keep to it.
Re: Motul 300V 5W40, 5000km, 60000km ODO, Subaru BRZ [Re: Popsy] #4246491
11/10/16 11:43 PM
11/10/16 11:43 PM
Rabbit Creek, Alaska
jayg Offline
jayg  Offline
For what such engines? These aren't high performers. It's a naturally aspirated boxer 4. 95-E10 is fine for that motor but 98 isn't hurting anything either.
2018 Ford Ecosport AWD- Napa 0w20
2017 Ram 1500 Ecodiesel- CP Triton ECT 5w40
1973 Datsun 240Z 10w30- VWC from '73
1973 Triumph Bonneville 750- M1 5w50
1967 BSA 441 Victor Special- M1 5w50
