Originally Posted By: Garak
Originally Posted By: edyvw
You can stay with Castrol 0W40. Personally in your area during winter I would switch to Castrol 0W30 or run 0W30 all year around if you are not making that many miles and you change oil once a year. 0W30 will do great in that engine and since it is DI engine, and 0W30 has lower NOACK then 0W40, it will create less CBU.
Buying Castrol 0w-30 A3/B4 is a little expensive up here compared to the 0w-40 A3/B4, which is available in jugs. The best bet is to wait for the 0w-40 jugs to be on special and get a few. Finding 0w-30 at under $8 a litre these days is next to impossible. It was fine when it and M1 0w-40 were the only game in town and were both only in 1 litre bottles, but fortunately, things have changed.
Bunny: Edyvw was recommending PCMOs, and approved ones at that. My recommendations are in the above paragraph, and are based upon price considerations. Shell and Imperial Oil also have approved lubricants, as you mention. NAPA Canada has the Shell stuff in EcoBoxes on special, if that floats your boat.
Yeah, I use 0W40 because price does not justify 0W30 considering it is same base stock oil.
If price difference is that big, Castrol 0W40 is way to go or Mobil1 0W40.
