Originally Posted By: Donald
Look at the factory jack and see exactly how it holds the pinch weld and where the lifting force is. On my Forester, it's on the inside edge next to the pinch weld.
This is a valid point.
OP, what's your vehicle and what does that factory lifting mechanism do?
On my vehicles, just a plain hockey puck does fine on the pinch weld. On a lot of vehicles, there's no need to cut a slot in it because the pinch weld itself, not the rocker above it, is the correct lifting point.
On vehicles I've owned, a plain hockey puck or block of wood are all you need because you're just trying to spread the force a little and not let the corners of the floor jack saddle damage the weld.
