OVERKILL
$100 Site Donor 2021
Originally Posted By: ofelas
Here is what I don't understand I reckon -
Amsoil ATF+4 = Pour point -53c and Brookfield viscosity = 9755 at -40c
ATF+4 (PetroCan) = Pour point -51c and Brookfield viscosity = 8380 at -40c
Is it pour point or Brookfield viscosity at -40 that indicates cold weather performance?
Full specs -
PetroCanada ATF+4 - http://lubricants.petro-canada.ca/resour...amp;language=en
Amsoil sig ATF - http://www.amsoil.com/lit/databulletins/g3110.pdf
I was told that ATL is too thin for summer use in the old non lockup 46RH
MRV is more important than pour point, so the PetroCan stuff has the better cold performance.
However
If the AMSOIL ATF+4 is a non-certified fluid and uses a PAO base, then it will retain its cold performance better IMHO.
Full specs -
However
