Originally Posted By: jimbrewer
Southern Rockies. Paved roads, mostly concerned about ice rather than snow. Tend to have lingering winters here, with occasional icy roads into mid April.So, tires are on the car from December to mid April.
Michelin's extra cost would cancel out longevity advantage.
They will not cancel longevity because:
1. Nitto is DEFINIATELY NOT better then Michelin or Bridgestone.
2. Michelin will feel more like A/S tire then Bridgestone
3. They have small, but still have, advantage over Bridgestone on ice.
4. Depending what size of tires you need, sometimes Bridgestone are more expensive then Michelin
5. Michelin ave tread 100% winter made. Bridgestone tread blocks are designed to turn into A/S tire after 50% of tread is used.
Bottom line, Michelin will feel more composed on road, dry road etc. NM is due for warmer winter since El Nino is gone. So yes, you might pay bit more, but Michelin will feel much better in NM then Bridgestone Nokian, Continental etc.
I tell people here in CO, if you do not ski often, stick to Michelin. Now, if you love to ski during Blizzard like I do, then that is different story.
