Let's Talk Porsche 911
by john_pifer - 02/21/20 02:51 AM
CLEARANCE ALERT O'Reilly's Mobil Super Oil
by GMguy84 - 02/21/20 01:27 AM
No more poulan / weedeater at walmart.
by jakewells - 02/21/20 12:44 AM
1991 Land Cruiser FJ80
by CCI - 02/20/20 09:57 PM
Gas price spread
by Chris142 - 02/20/20 09:28 PM
Need an Ecoboost Oil
by kstanf150 - 02/20/20 08:47 PM
2007 sedona
by macdole99 - 02/20/20 08:29 PM
USB-C, USB 3.0, 3.1Gen1, 3.1Gen2 Confusion.
by SubLGT - 02/20/20 08:12 PM
Apple Air Pro 2 tablet, How to send a link by email
by JLawrence08648 - 02/20/20 07:56 PM
Needed A Truck
by MParr - 02/20/20 07:21 PM
Battery Charger/Desulfator
by DBMaster - 02/20/20 06:45 PM
STP 0W-16 found in NC Autozone
by mv6845 - 02/20/20 06:20 PM
Cats
by Anduril - 02/20/20 06:12 PM
Are Onan oil filters now Fleetguard?
by atikovi - 02/20/20 05:57 PM
Car overheating under different conditions.
by MichaelRS - 02/20/20 04:39 PM
2008 CR-V AT Question
by Gebo - 02/20/20 04:18 PM
2019 Sienna
by s2krunner - 02/20/20 04:01 PM
onuryas, vidirola, CharlotteB, Grennx, coverage
70766 Registered Users
74 registered members (4WD, Astro_Guy, bullwinkle, 2002 Maxima SE, Bailes1992, 7 invisible), 1,465 guests, and 20 spiders.
Topics301,732
Posts5,201,619
Members70,766
Page 1 of 7 1 2 7
Valvoline Premium Blue Restore #4230571 10/21/16 11:35 AM
G-MAN Offline OP
I just called the local Cummins service center about this oil. They have it in stock and it's $73.00 a gallon. crzy
2007 Mercedes ML350 (Mobil 1 0w40)
2019 Camaro 1LT 3.6 (RLI 5w40 HD Low Ash)
Re: Valvoline Premium Blue Restore [Re: G-MAN] #4230580 10/21/16 11:46 AM
CT8 Offline
Run this oil and you tires will never wear out, The mpgs will increase, The uoa will show negative wear metals as the oil rebuilds the engine as you drive, Good stuff.
2015 F150 2.7
2018 F350 6.2
Re: Valvoline Premium Blue Restore [Re: G-MAN] #4230581 10/21/16 11:47 AM
L
Lolvoguy Offline
L
why's it so special?
06 Lexus IS350- Wife
88 BMW 325is- Mistress
Say "no" to Turbo!
Re: Valvoline Premium Blue Restore [Re: G-MAN] #4230602 10/21/16 12:07 PM
K
KGMtech Offline
K
blue bottle.
2017.5 Nissan Rogue SV FWD
2013 Nissan Maxima SV
2009 Ford Flex SEL FWD
1984 Yamaha XJ750RL
Re: Valvoline Premium Blue Restore [Re: Lolvoguy] #4230647 10/21/16 01:01 PM
demarpaint Offline
My thoughts exactly.
God Bless Our Troops
Re: Valvoline Premium Blue Restore [Re: demarpaint] #4230700 10/21/16 02:42 PM
K
Kira Offline
K
"The only one endorsed and recommended by Cummins..." Hmmmm....keeps your new Cummins diesel RAM within warranty?
Re: Valvoline Premium Blue Restore [Re: Lolvoguy] #4230717 10/21/16 03:14 PM
G-MAN Offline OP
According to the MSDS, it's got some pretty exotic base oils, including 50% ester (and I suspect this is a bio-based ester), and 30% PAO. This was developed specifically for Cummins by Valvoline and is only sold at Cummins service centers.
Re: Valvoline Premium Blue Restore [Re: G-MAN] #4230737 10/21/16 03:55 PM
R
Rat407 Offline
R
It is specifically used to clean up and keep clean the inside of the engine. Hence "Restore". According to Terry Dyson, this specific formula is a very exotic blend. I was going to try it but for now that is way past my kitchen pass money.
2002 Silverado 5.3 0w-20 AMSOIL
Re: Valvoline Premium Blue Restore [Re: G-MAN] #4230753 10/21/16 04:41 PM
A
austinlunsford Offline
A
I'd try it, if anyone can find a $53 rebate per gallon.
1997 F250 HD 7.3: Delvac 5W-40
2002 F150: M1 HM 0W-20
2003 Taurus: M1 EPHM 5W-20
2016 Renegade: Valvoline Modern Engine 0W-20
Re: Valvoline Premium Blue Restore [Re: G-MAN] #4230772 10/21/16 05:16 PM
U
userfriendly Offline
U
Premium Blue vs Royal Purple. It looks like Valvoline has entered the boutique market.
Re: Valvoline Premium Blue Restore [Re: G-MAN] #4230846 10/21/16 07:37 PM
CT8 Offline
How many people with Class 8 vehicles are going to use this when $13.00 per gallon Delo or Delvac and Rotella etc will allow over a million miles OTR. 12 gallons @ $73.00 per gallon! A thousand dollar + oil change. I hope it saves a ton of fuel! It must come with coupons for the lot lizards at select truck stops across the nation.
2015 F150 2.7
2018 F350 6.2
Re: Valvoline Premium Blue Restore [Re: CT8] #4230853 10/21/16 07:50 PM
G-MAN Offline OP
This is not designed to be used full-time as a replacement for regular HD engine oils. It was developed by Valvoline in conjunction with Cummins engineers to address a specific problem some of their engines were having with excessive carbon buildup on the rings, which would cause them to stick and send oil consumption through the roof. Cummins TSB150163 goes into detail as to when and how to use this oil to clean out an engine that is suffering from this problem. Once the engine is cleaned out, Cummins recommends Restore be used for one OCI per year thereafter to prevent the carbon buildup from recurring. Compared to the cost of a tear down and ring replacement, $1000 for an oil change is chump change.
Re: Valvoline Premium Blue Restore [Re: G-MAN] #4230933 10/21/16 10:32 PM
T
TiredTrucker Offline
T
Well if Cummins (and the other brands) would rely solely on SCR for NOx control and quit making the engines eat their own feces via EGR, then they might not have that ring carbon buildup.
But it is pretty sad that they build engines that need a one OCI a year dose of this stuff. $730 for the typical Cummins ISX. That is 7 oil changes (just the oil) on bulk Delvac, Rotella, or Delo at the local Mack dealership lube shop I use. For a typical ISX, it is usually 5 oil changes a year (25,000 mile intervals). So the yearly oil cost would go up substantially. 5 oil changes for $500, or 4 for $400 and one for $730 for a total of $1130, again, just for the oil. Over 200% annual increase in oil costs.
Yet one more reason I will more than likely never get a Cummins again. Not after getting burned on two ISX's. I had a great fondness for their N-14, but I have no brand loyalty. Not when it costs $30K for a engine.
Freedom is not about having the choice to do what you want, but the choice to do what you ought.
Re: Valvoline Premium Blue Restore [Re: G-MAN] #4231365 10/22/16 04:54 PM
U
U
I guess 10w30 in an ISX, especially during break-in wasn't such a good idea after all.
Re: Valvoline Premium Blue Restore [Re: TiredTrucker] #4231874 10/23/16 09:55 AM
B
BrocLuno Offline
B
I'm in your camp. And if I were not hauling into or out of an air quality restricted area, or using "not for hire", I'd just stay with an older engine and skip all this stuff...
But, in the modern world you really need to look at cost of ownership over the long haul if wanting to be in trucking...
Page 1 of 7 1 2 7
