Originally Posted By: bigjl
Originally Posted By: d00df00d
Originally Posted By: supton
At least for a VW, if you leave the engine running, and open the hood, if you hear something like marbles being rattled around in a tin can, then that is the warning. I don't recall any change in how it drove (jerkiness).
Not sure if a Sonata would have the same failure mode.
Good call. Very often, dual-mass flywheels are used to mask gear rattle in the transmission. In those applications, it's probably not uncommon to get a rattle if the flywheel's damping mechanism is badly worn.
Have never heard that about a DMF.
Can you give me a pointer on a source to read up about that? As I have only read that DMFs are used to make vehicles smoother, especially on diesel cars which is the first kind of vehicle I owned that came with a DMF.
I read in the Handbook for my 05 Mondeo 2.0 Tdci that you should always start and stop a DMF equipped vehicle with the clutch depressed.
Your response made me realize that I had worded part of my post clumsily. Let me try again.
The point of a DMF is to damp vibration. In doing so, yes, it helps make the vehicle smoother. That's probably the primary benefit.
Some cars also have a lot of gear lash in the transmission -- enough to make noise if solidly coupled to the engine. The vibration damping effects of a DMF will reduce that noise. Thus, if the DMF fails (or is swapped out with a SMF), it's possible that the noise will return.
My old '95 Maxima had a SMF and no gearbox rattle. My '96 M3 had a DMF; if I had swapped it for a lightweight SMF, it would have made loud gear rattle.
