Originally Posted By: gman2304
I was tempted by that brand last year when I replaced my JD 345 clutch. I decided to go with the OEM JD clutch for about the same money. The original JD lasted 15 years.
Normally I'd do the same, but this would save me $80-$100 over the original.
Originally Posted By: bugeye
Positive reviews on "only cub cadets"
Good to know. I may have to some lurking over there and read up on them.
Originally Posted By: JTK
I've never heard of the brand. Used and OEM or two. More curious about the project mower! Old E-clutch removal is not a joy.
E-clutch came right off- no fighting whatsoever!
Mower is a Snapper 2000GT (actual model is GT180K 485H) that a guy gave me as he was moving away. I've always had a soft spot for these (and similar old Snapper mowers) as an old neighbor had something like it when I was growing up. I'll always remember it because it had a big twin (Briggs Vanguard I think) and dual exhaust right out the front. It sounded mean and grizzly to a kid like me.
Well when this thing fell in my lap with it's 18hp Kohler Magnum (with front exit dual exhaust), I jumped on it. It was a case of leaping before I looked... He said the hydro was slowing down quite a bit and that it seemed to go faster in reverse than forward. He bought a filter and gave me some 50w transmission oil and thought that might help... I figured the hydro was toast but tried anyway- no dice. Then I thought no biggie... We have a hydro rebuilder about 30 miles away- yeah, they told me that parts are near impossible to find and that if they did have them or could get them I'd be looking at $500-600. Hmmm. So I put it on the back burner, resolving to call Eaton and/or tear it down to figure out the problem. I had already rebuilt the carb to get it to run and replaced the starter and head gaskets and put a battery in it- like I said... I got a little ahead of myself, but figured that if the worst were to happen, I could likely sell the engine and recoup my money.
Every now and again I'd search for a used one and wasn't really liking what I saw. Last new price was somewhere between $1500 and $1800! Well just the other day, I searched again and found the same model (Eaton 851) on e-bay, new in box... for about $250.00! So for $275.00 to my doorstep from Quebec, I figured I couldn't go wrong. It showed up and the only problem I saw right away was that it was a CW rotation unit and mine is CCW. Then I thought that I could mix and match parts to make mine work- until I saw in the manual that rotating the pump cover plate around 180* should work! The hydro body even has casting marks for CW and CCW rotation- just turn the pump cover (it has an arrow for alignment purposes) to whichever you need.. Score! After doing that and transferring the direction control shaft from my old unit, I think I may be in business. Gearing could be an issue too, but I'll cross that bridge when I come to it.
So now I'm just trying to piece it back together and see what she's made of.
