Stabilizer effectiveness really depends on the type and dosage used.
-I only recommend the marine grade stabilizer as it helps prevent moisture contamination from the ethanol, all others do nothing for moisture.
-I usually run a double dose of stabilizer
-I run the equipment for a few minutes to get the stabilizer in the carb
-The most sure-fire way is to empty the fuel out completely, especially if machine is stored outside or for extended periods of time
-Running the equipment for a few minutes every so often does nothing, unless you run it long enough to burn all of the moisture contaminated fuel in the tank
