Hi friends, I'm trying to decide on brake pads for my 2005 4Runner Limited 4WD. Either the OEM Toyota pads made by Sumitomo which have a "FF" friction rating for the front and "EE" (see second last paragraph) for the rear. Or the Akebono Performance pads with a "GG" friction rating.
Both pads have a good reputation. I see low braking temperatures overall, especially considering the Canadian winters. I may not have time/distance to waste getting my pads/rotors up to temperature for desirable friction while performing an emergency stop in the winter.
I'll have to buy front and rear shims for the Toyota pads, the Akebono appear to come with shims. The Toyota OEM Sumitomo pads are ~$40 more per axle, so at least $100 more total after buying Toyota shims and pads from the dealership. I would buy the Akebono pads online and ship to Canada.
Complicating matters, the Toyota Sumitomo pads I require for the rear are PS549, when looking at this thread for 120 series toyotas (very very similar to 4Runners) the poster has a picture of a Toyota Sumitomo PS549 pad with blue painted backing plate and the friction rating is EE, seems a bit low to me, almost like a longevity type compromise from Toyota.
Here is the reference thread : http://www.toyota120.com/html/rear_brake_pads.html
It's a tough call as the Toyota Sumitomo pads cost more and should last longer, but seem to have an unusually low friction rating in the rear. The Akebono Performance pads have higher ultimate friction rating but would they need to build heat to get to that level?
