The Gasket on the 301 is the same as on the factory filter, but the can on the 301 is bigger around, if this makes sense. If you look at the 301, the gasket is not at the edge of the can, its smaller. It will screw on and seal, but its so much bigger you will have to make sure it won't hit anything on the engine or truck.
