overfilled my crankcase by 3/10 of a liter - problem?
by tom in boise - 05/29/20 08:49 AM
Espresso
by buster - 05/29/20 08:34 AM
I didn't believe there were fake spark plugs.
by JustinH - 05/29/20 08:14 AM
New Tire Selection
by artbuc - 05/29/20 07:44 AM
Well question
by supton - 05/29/20 07:11 AM
Cable Modem Thoughts/Recommendat
ions?
by alarmguy - 05/29/20 07:10 AM
Tire choice 2016 Lexus es 350
by Toros - 05/29/20 06:20 AM
Infineum trends: Passenger vehicles (2019)
by Gokhan - 05/29/20 05:11 AM
Another story from the service bay
by clinebarger - 05/29/20 12:11 AM
KIA TYPE 4 (M) ATF
by flinter - 05/28/20 08:49 PM
My new Henry 22 Magnum rifle
by tig1 - 05/28/20 08:45 PM
Mobil 1 M-102 for 3 6000km oil changes?
by pktrkt - 05/28/20 08:33 PM
1/2 75W-90 1/2 75W-110 Can you mix equal parts
by jrommelt - 05/28/20 08:22 PM
Mazda b4000 to the junkyard
by HyundaiAbuser - 05/28/20 08:20 PM
2017 RAM 2500 6.4 Hemi AMSoil and PUP
by Gondul - 05/28/20 07:50 PM
Nail in tire, what would you do?
by Brybo86 - 05/28/20 07:44 PM
Any decent lap tops for $200.00 or less?
by BAJA_05 - 05/28/20 06:49 PM
New PW with Honda 190 engine - Ethanol treatment?
by DirtyApe - 05/28/20 06:38 PM
What size tube should a 110/50-6.5 Tire use?
by taztheman - 05/28/20 06:14 PM
Kboggs, oldcodger, cwllams1, Danwrig, DanielR
71558 Registered Users
118 registered members (830Lee, ABN_CBT_ENGR, AandPDan, 2015_PSD, 2K2AcuraTL, 4WD, 6 invisible), 2,029 guests, and 53 spiders.
Topics306,007
Posts5,284,601
Members71,558
BMW X5 35d 9700mi D1 LE 5W30 #4209174 09/22/16 06:01 PM
M
m37charlie Offline OP
M
Fe 59 down from 89
Cr 3 down from 4
PB 1
Cu 13 down from 15
Al 17
Ni 1
all others <1
Mg 594
Ca 1535
P 700
Zn 809
Mo 41
B 80
Vis 11.1
Soot 0.4%
TAN 3.27 down from 3.64
TBN 4.4 up from 4.0
Midway thru this cycle I deleted emissions, got new exhaust system and hp/torque cranked up ~10%. MPG is up 10%
I'm almost out of D1 LE so next change I'll use D1 SHC 5W40 and try 15Kmi OCI since it has TBN=16
Charlie
05 Unimog U500/Unicat camper/Delvac 1 SHC ACEA E4/E5
09 BMW X5 35d/Delvac1 LE 5W30
88 Toyota OJ50LV OM314 motor D1 SHC
52 Dodge M37/Hercules diesel
Re: BMW X5 35d 9700mi D1 LE 5W30 [Re: m37charlie] #4209396 09/23/16 02:40 AM
U
UltrafanUK Offline
U
Not another air pollution fan!
Not sure what the legal situation is in the US as it varies from state to state, but removing emissions control equipment is an illegal act in the EU or UK. It often invalidates the insurance policy if it is not approved as an engine modification. You can get an approval for track use but not for public roads from most insurers.
Re: BMW X5 35d 9700mi D1 LE 5W30 [Re: UltrafanUK] #4209413 09/23/16 03:57 AM
rooflessVW Offline
Hey, this isn't the UK and our laws aren't the same!
Let it burn, baby! :P
"Zed's dead baby, Zed's dead."
Re: BMW X5 35d 9700mi D1 LE 5W30 [Re: UltrafanUK] #4209573 09/23/16 10:45 AM
M
M
What is the longest lasting most planet threatening emission product?
Soot that falls to the soil in a few hours and isn't an issue in my area?
NOx that quickly decomposes and does NOT form photochemical smaog in my area?
Or CO2 that lasts for thousands of years and threatens to melt the polar icesheets and raise sea level over 100m?
My modification produces 10% LESS CO2 than previously.
NOx and soot are local pollutants, CO2 is a planetwide pollutant. The car is in Alaska, not in London. So I am doing the planet a favor.
Charlie
Re: BMW X5 35d 9700mi D1 LE 5W30 [Re: m37charlie] #4209629 09/23/16 12:20 PM
rooflessVW Offline
Charlie
cheers
Re: BMW X5 35d 9700mi D1 LE 5W30 [Re: rooflessVW] #4210176 09/24/16 05:30 AM
U
UltrafanUK Offline
U
Charlie
cheers
Removing the EGR and CAT does not effect CO2, if your figures have changed it is due to some other factor or simply a change in the weather. Obviously removing a DPF does change the soot readings, BUT if you read up on the effects of NOX it is involved in the production of fine particle contamination and that does remain in the atmosphere, so it's not just a local issue. It's also bad news for the occupants of the vehicle when it is stationary at idle or the tailwind exceeeds the vehicles speed.
The big issue I have about people that boast about deleting emissions control gear is that you are setting a bad example in a public forum. Most of the folks that then follow your example will fail to declare the modification to their insurance company and many of the cheaper new online insurance providers are very good at finding any way possible to reject a serious claim and undeclared mod's are one area they will check.
Re: BMW X5 35d 9700mi D1 LE 5W30 [Re: m37charlie] #4210494 09/24/16 01:25 PM
M
M
"if your figures have changed it is due to some other factor or simply a change in the weather"
The mpg has increased consistently 11% over 6 months, compared to previous summer. No more fuel burned in DPF burnouts. Driving pattern absolutely the same - to and from work (9.1mi each way) and grocery store is pretty much it for this particular vehicle. And I am aware of seasonal difference between summer and winter fuel.
Charlie
Re: BMW X5 35d 9700mi D1 LE 5W30 [Re: m37charlie] #4210502 09/24/16 01:40 PM
U
UltrafanUK Offline
U
Charlie
Sounds like the DPF was nearly blocked, as they only use about 2 or 3% more fuel if in good order. I'm not a fan of DPF systems as they do cause a number of problems for cars that are short tripping and they were introduced before being properly developed. 9 miles is probably not enough in winter to do a full regen cycle.
Re: BMW X5 35d 9700mi D1 LE 5W30 [Re: m37charlie] #4210514 09/24/16 02:13 PM
M
M
I do not think the DPF was plugged. The mileage numbers prior modification were unchanged since the vehicle was virtually new. The vehicle does get about once a month (about once every 6-700mi) longer trips, 30-80 miles. Personally, my top bete noire in diesel emission systems is EGR. Both my Unimog and BMW had EGR failures early under warranty, including ingestion of coolant, potentially disastrous. And a particularly bad thing if one is in, say, the middle of the Gobi Desert (2 months ago).
Charlie
Re: BMW X5 35d 9700mi D1 LE 5W30 [Re: UltrafanUK] #4211579 09/25/16 11:33 PM
G
Garak Offline
G
In the end, that depends upon one's jurisdiction. In this province, another low population density area, the provincial government and the main insurer (a provincial Crown) couldn't care less if you took every piece of emissions equipment off the vehicle and threw them into the garbage. If people in other jurisdictions wish to make uninformed decisions, that's up to them.
Plain, simple Garak.
Re: BMW X5 35d 9700mi D1 LE 5W30 [Re: m37charlie] #4213943 09/28/16 09:18 PM
spiderbypass Offline
Seems like the Delvac LE changed formulation again to include Magnesium as well. What was the bottle date if you have that information? Sounds like the vehicle is running much better since the changes. I think this engine was probably one of the hardest engines on oil with all the emission systems intact. Thank you for sharing oil analysis.
Insecurity with overcompensation are the root of evil deeds.
Re: BMW X5 35d 9700mi D1 LE 5W30 [Re: m37charlie] #4214244 09/29/16 10:41 AM
M
M
It's old, I got it from the UK in 2011.
Charlie
Re: BMW X5 35d 9700mi D1 LE 5W30 [Re: UltrafanUK] #5008433 02/11/19 10:59 PM
M
M
What is more important mr ultrafan?
Smog in London from cars in Alaska or addition of CO2 that goes everywhere and is pulled down only over thousands of years?
Re: BMW X5 35d 9700mi D1 LE 5W30 [Re: m37charlie] #5008446 02/11/19 11:40 PM
5
555 Offline
5
Did the OP have a question?
84 XJ6 M1
92 Mustang 5.0 Redline
99 Tahoe 2 door Castrol Edge
99 MX5 Miata Anniversary Edition M1
04 Subaru STi Motul
