I have a 2014 GMC Sierra 1500 'double-cab' with stock 265/70/17 tires. I was wanting to go with a narrower and slightly taller tire, using the same factory wheels. The stock tires are 31.1" tall and 10" wide.
I was looking at 235/80/17 which is 31.8" tall and 9.3" wide. This is my preferred choice so far.
Then there is the in between choice, 245/75/17 which shows 31.5" tall and 9.6" wide.
Just started research, assuming they fit on the factory 17" wheels. Then there is the issue of about all but the Winter tires only come in load range 'E'. I actually would like to go with the E tires, with a midrange PSI on the pressure. I only tow midlin to lighter weights and don't care if my ride is a bit more stiff. I also don't care if my speedometer is off some.
I thought I'd swing through here before the local tire shop tells me all the reasons my plan isn't valid. My farm buddy sees no problem with the idea.
