HTSS_TR
Thread starter
Originally Posted By: Drew99GT
Originally Posted By: JHZR2
What is the white plume? Is it sand/dust from the gravel, water from some water-filled barrels or the radiator releasing steam, or is it the brakes themselves?
I'd say it's the brakes being fried. From what I've read, if you have a heavy load and you overcome the ability of the engine/jake brakes to maintain a decent without riding the brakes and then you ride the brakes, it's pretty easy to cook them until their gone. Seen plenty of big rigs on Interstate 70 with smoking brakes in Colorado. On the steeper passes, semi trucks I believe have a 45 mph decent speed limit.
Originally Posted By: Blkstanger
First rule.Never ride your brakes! EVER!
The best way to brake while going down a grade is stab braking. Say you want to travel down the grade at 45mph. Your truck gains speed up to 50mph. You get on the brakes hard and slow yourself to 35mph. Then stay off of them and let the truck slowly gain speed up to say 45-50mph until you brake again. This allows the brakes to cool between slowing events. I drive a lot of mountains and have never had a brake problem using this method.
Agreed. Riding the brake down hill is the wors thing a driver can do to his/her brake system.
On that Grapevine section of highway I-5 I only stab the brake every 1/2 miles or so, that way the brake is cool while coasting down steep hill. Same stab braking on Cajon pass of highway I-15 to Vegas.
