2020 330i xDrive Loaner
by MCompact - 06/04/20 10:02 PM
Appliance repair?
by motor_oil_madman - 06/04/20 09:44 PM
Glad we got a seasonal RV site
by Pat in Speedway - 06/04/20 09:19 PM
Mobil 1 AP Clearance at Wal-Mart
by KeithS_NW_Ohio - 06/04/20 09:07 PM
Recent experience with a Michelin Defender
by FordSVTGuy - 06/04/20 08:46 PM
music quality of speakers in the 70's vs now
by raaizin - 06/04/20 08:15 PM
pressure washer care
by raaizin - 06/04/20 08:06 PM
Watch Forums?
by maverickfhs - 06/04/20 07:53 PM
Who has a media/sand blast cabinet?
by spasm3 - 06/04/20 07:39 PM
Why isn't Polyethylene Glycol standard?
by RamFan - 06/04/20 06:37 PM
Motorcraft GF-6 at Quick Lane.
by Gene K - 06/04/20 06:29 PM
OEM Honda wiper blade curvature
by mclasser - 06/04/20 06:24 PM
GDI vs. MPFI OCI's
by LubricatusObsess - 06/04/20 06:19 PM
Mobil “full synthetic”
by 53' Stude - 06/04/20 06:01 PM
1992 Ford Ranger Brake Fluid Type
by yeehaw1960 - 06/04/20 04:21 PM
Of 0w-20 oils, which have highest VI
by Bill_W - 06/04/20 03:44 PM
Gasket vs RTV?
by supton - 06/04/20 02:29 PM
List Impossible Sparkplug Replacement
by borgward - 06/04/20 01:31 PM
stubby73, Polkaman, Ramboagain, tekfire07, Kernal
71608 Registered Users
90 registered members (14Accent, 2K2AcuraTL, 87sammy, 97prizm, aleneros, 55hambone, 8 invisible), 1,724 guests, and 33 spiders.
Topics306,224
Posts5,288,540
Members71,608
Flared tubing vs hose and clamps. #4194124 09/03/16 01:20 PM
TheLoneRanger Offline OP
Hi all. I'm considering mounting a B&W external spin-on filter, and wondering about
connecting it to the radiator fittings with flared tubing instead of the usual hose
and clamps.
Would the hard lines be that much more reliable than the rubber hose, and worth
the added expense and labor? I already have a flaring tool and tubing bender.
Some days you eat the bear, some days the bear eats you.....
Re: Flared tubing vs hose and clamps. [Re: TheLoneRanger] #4194165 09/03/16 02:39 PM
Donald Offline
The pressure is pretty low. Transmission cooler hose and clamps will be fine. I would get transmission hose so the ATF does not damage the hose.
I would go with a Magnefine. It will filter just fine. And has a magnet in the flow of the ATF.
2015 Ford F-250 w/Powerstroke
Re: Flared tubing vs hose and clamps. [Re: TheLoneRanger] #4194239 09/03/16 04:25 PM
L
Leo99 Offline
L
Use ATF not fuel line hose. Easy peasy.
Without data you're just another person with an opinion. W. E. Deming
2004 Corolla 125,000 miles
2004 Rav4 399,852 miles (RIP)
2015 Camry 101,000 miles
2020 Rav4 6,000 miles
Re: Flared tubing vs hose and clamps. [Re: TheLoneRanger] #4194259 09/03/16 05:07 PM
Chris142 Online Content
Online Content
I use 2 clamps and gasket cinch to glue the hose into the metal. Once that dries it won't ever come off
87 F250 Valvoline 15w40
Z400 castrol T 10w40
Can am Maveric edge 5w40
57 case tractor Chevron sae30
Re: Flared tubing vs hose and clamps. [Re: Chris142] #4194267 09/03/16 05:16 PM
4WD Offline
Ok, I've used RTV for that - but are you using an actual glue ?
Re: Flared tubing vs hose and clamps. [Re: Leo99] #4194661 09/04/16 05:34 AM
L
Lubener Offline
L
Agree. Also if you can find clamps for fuel injection would be an improvement over the standard issue worm clamp.
The "thinking" man's friend.
Re: Flared tubing vs hose and clamps. [Re: Lubener] #4195300 09/04/16 10:09 PM
Thanks for the replies and tips. Seems the consensus is to use hose and clamps so the
hard lines are probably overkill for a filter installation.
I do have ATF hose, and one other question. What about using the constant tension/spring
type clamps rather than the worm gear, or for that matter the FI clamps?
Re: Flared tubing vs hose and clamps. [Re: TheLoneRanger] #4201283 09/12/16 02:56 PM
carock Offline
In practical experience, I have had better luck with the worm style clamps than the FI style clamps.
