13 Corolla PCV
by AJB0009 - 05/25/20 04:24 PM
SpaceX Launch - Wednesday
by MasterSolenoid - 05/25/20 04:15 PM
Atf for my E4od
by R1jake - 05/25/20 04:04 PM
Having trouble finding the right part (VW)...
by gregk24 - 05/25/20 04:03 PM
Need a sensible but fun daily
by dparm - 05/25/20 03:52 PM
FJ cruiser knock sensors
by Chris142 - 05/25/20 03:51 PM
Rock Auto now carries Maval steering racks and pumps
by slacktide_bitog - 05/25/20 03:10 PM
Review: Cardone Reman Power Steering Pump
by RevelationLion - 05/25/20 02:09 PM
Carvana
by Bogdon - 05/25/20 02:06 PM
Mitsubishi SP-III universal fluid
by MontePrix28 - 05/25/20 12:22 PM
4th Gen Ram 1500 tranny pan question
by stenerson - 05/25/20 11:26 AM
logic behind no trans dipstick?
by flinter - 05/25/20 11:25 AM
2012 Dodge Charger patrol car alternator meltdown
by IMSA_Racing_Fan - 05/25/20 11:25 AM
MMO vs Oil Consumption.
by Vladiator - 05/25/20 11:19 AM
Oil filter – clean/empty – reuse
by 2K2AcuraTL - 05/25/20 10:40 AM
Mazda 3 1.6 DV6C which Oil to buy
by mossietheno1 - 05/25/20 09:58 AM
APR dyno: Passat 2.0T 87 vs 93 Octane
by wemay - 05/25/20 09:31 AM
Quick Lane attempted to fraudulently upsell me
by Hermann - 05/25/20 08:58 AM
Frankenbrew question
by jdw1222 - 05/25/20 08:40 AM
showtyme1958, rickyradit, YogiTheCat, StevePLR, BBC_bias
71526 Registered Users
104 registered members (2015_PSD, 53' Stude, ABN_CBT_ENGR, 86cutlass307, aba4430, 13 invisible), 2,769 guests, and 42 spiders.
Topics305,861
Posts5,281,591
Members71,526
Flared tubing vs hose and clamps. #4194124 09/03/16 01:20 PM
TheLoneRanger Offline OP
Hi all. I'm considering mounting a B&W external spin-on filter, and wondering about
connecting it to the radiator fittings with flared tubing instead of the usual hose
and clamps.
Would the hard lines be that much more reliable than the rubber hose, and worth
the added expense and labor? I already have a flaring tool and tubing bender.
Some days you eat the bear, some days the bear eats you.....
Re: Flared tubing vs hose and clamps. [Re: TheLoneRanger] #4194165 09/03/16 02:39 PM
Donald Offline
The pressure is pretty low. Transmission cooler hose and clamps will be fine. I would get transmission hose so the ATF does not damage the hose.
I would go with a Magnefine. It will filter just fine. And has a magnet in the flow of the ATF.
2015 Ford F-250 w/Powerstroke
Re: Flared tubing vs hose and clamps. [Re: TheLoneRanger] #4194239 09/03/16 04:25 PM
L
Leo99 Online Content
Online Content
L
Use ATF not fuel line hose. Easy peasy.
Without data you're just another person with an opinion. W. E. Deming
2004 Corolla 125,000 miles
2004 Rav4 399,852 miles (RIP)
2015 Camry 101,000 miles
2020 Rav4 6,000 miles
Re: Flared tubing vs hose and clamps. [Re: TheLoneRanger] #4194259 09/03/16 05:07 PM
Chris142 Offline
I use 2 clamps and gasket cinch to glue the hose into the metal. Once that dries it won't ever come off
87 F250 Valvoline 15w40
Z400 castrol T 10w40
Can am Maveric edge 5w40
57 case tractor Chevron sae30
Re: Flared tubing vs hose and clamps. [Re: Chris142] #4194267 09/03/16 05:16 PM
4WD Offline
Ok, I've used RTV for that - but are you using an actual glue ?
Re: Flared tubing vs hose and clamps. [Re: Leo99] #4194661 09/04/16 05:34 AM
L
Lubener Offline
L
Agree. Also if you can find clamps for fuel injection would be an improvement over the standard issue worm clamp.
The "thinking" man's friend.
Re: Flared tubing vs hose and clamps. [Re: Lubener] #4195300 09/04/16 10:09 PM
Thanks for the replies and tips. Seems the consensus is to use hose and clamps so the
hard lines are probably overkill for a filter installation.
I do have ATF hose, and one other question. What about using the constant tension/spring
type clamps rather than the worm gear, or for that matter the FI clamps?
Re: Flared tubing vs hose and clamps. [Re: TheLoneRanger] #4201283 09/12/16 02:56 PM
carock Offline
In practical experience, I have had better luck with the worm style clamps than the FI style clamps.
