List an oil Additive you'd use / No Comments
Lubro Moly MoS2 and Engine Flush
Redline ZDDP additive
Liqui-Moly MOS2
Liqui-Moly motor oil saver
Schaeffer Moly EP
Camguard (for aircraft engines)
BG MOS
I'm sure there are others...
Lubro Moly Engine Oil Saver
Bio/Tech Engine Oil Protectant with LXE® Technology
Liqui Moly oil flush and Ceratec are the main additives I have used in my old TDI. If I had any oil leaks that were beyond economic repair, I would also used Motor Oil Saver stop leak additive.
If you are going to use oil additives, it is a good idea to stick to the larger engine oil companies and steer well clear of the back street snake oil mixers.
Originally Posted By: Pop_Rivit
Whatever additives the oil companies already put in the bottle. Beyond that, I don't waste my money on any of them.
+1
What's that one with the teflon? I can't remember the name but they advertise the slipperiest surface on planet earth.
Also, I meant BG MOA in my previous post. I accidentally put MOS...
Tufoil
Liqui Moly MoS2 for the '25 & '70
Liqui Moly MoS2 plus Motor Oil Saver for the '37 (she's thirsty)
Used Ceretec once in the '70, but Liqui Moly advised it's formulated for newer engines.
