Washed the Terrain
by gregk24 - 10/13/19 10:23 PM
Oil recommendation for my flat tappet cam?
by fusseli - 10/13/19 10:02 PM
Less oil consumption when near add line?
by ledslinger - 10/13/19 09:33 PM
Honda Accord V6 Destroyed -- Timing Belt Failure
by CrackyWainwright - 10/13/19 08:48 PM
Valvoline Advanced Full Synthetic
by GaryPoe - 10/13/19 08:36 PM
Help!!!! 2000 GM 2.4 LITER TWIN CAM WATER PUMP
by Prich - 10/13/19 07:46 PM
Oil running off dipstick after hard driving
by DV0993 - 10/13/19 07:39 PM
Craftsman YT4000 - Slow uphill
by Covington - 10/13/19 07:23 PM
Outside Temperature Gauge
by rrretiree7 - 10/13/19 06:59 PM
Battery judgement based on analyzer
by tvaughn0712 - 10/13/19 06:49 PM
Low number plate
by Nayov - 10/13/19 06:34 PM
Valve Lubrication help
by MikeDanger - 10/13/19 05:31 PM
Havoline Pro DS Problems/Benefits?
by TheLawnRanger - 10/13/19 04:40 PM
Reusing oil filter
by Brojo - 10/13/19 04:11 PM
Vehicle Turbo Efficiency
by Al - 10/13/19 03:58 PM
Conv When Car Manual Calls For Syn Blend
by Mr_Luke - 10/13/19 03:01 PM
ATF contamination in PS Fluid--Honda CR-V 2007
by Blurider24 - 10/13/19 02:53 PM
Mag1 gear oil at PepBoys
by kstanf150 - 10/13/19 02:33 PM
1000Bulbs.com 500 at Talladega
by bdcardinal - 10/13/19 12:35 PM
LMLowner, Gordonhersh, Starrman, Covington, pktrkt
69548 Registered Users
69 registered members (4WD, AdditiveOCD, 19jacobob93, A_User55555, andyd, 2 invisible), 1,557 guests, and 32 spiders.
Topics295,936
Posts5,087,651
Members69,548
Most Online3,532
Jul 30th, 2019
Page 1 of 12 1 2 12
List an oil Additive you'd use / No Comments #4190280 08/30/16 02:33 AM
SuperDave456 Offline OP
I Thought it'd be fun to list Oil Additives you trust and would use or have used.
No other comments please.
I'll go first.
Lubro Moly Engine Oil Saver
Re: List an oil Additive you'd use / No Comments [Re: SuperDave456] #4190285 08/30/16 02:43 AM
K
Kibitoshin Offline
K
Lubro Moly MoS2 and Engine Flush
Redline ZDDP additive
Shin Gekiretsu Shin'ou'hou
01 Toyota Tundra 2WD V8 4.7L
02 Chevy Silverado C1500 V8 5.3L
Re: List an oil Additive you'd use / No Comments [Re: SuperDave456] #4190288 08/30/16 03:04 AM
SR5 Offline
Liqui-Moly Friction Reducer - (MoS2) Molybdenum Disulphide oil additive
Castrol Edge 10W30 A5/B5 + Wesfil-Cooper Z154
Re: List an oil Additive you'd use / No Comments [Re: SuperDave456] #4190295 08/30/16 03:33 AM
F
Farmer Offline
F
Liqui Moly Anti Friction
Liqui Moly Motor Oil Saver
Liqui Moly Pro Line Engine Flush
ATP-205
Re: List an oil Additive you'd use / No Comments [Re: SuperDave456] #4190297 08/30/16 03:54 AM
FowVay Offline
Liqui-Moly MOS2
Liqui-Moly motor oil saver
Schaeffer Moly EP
Camguard (for aircraft engines)
BG MOS
I'm sure there are others... smile
Re: List an oil Additive you'd use / No Comments [Re: SuperDave456] #4190305 08/30/16 04:27 AM
SteveSRT8 Offline
Kreen is the only additive we ever use, and sparingly at that...
"In a democracy, dissent is an act of faith."
J. William Fulbright
Best ET-12.79 @ 111 mph
4340 pounds, Street tires
Just like we go to Publix
Re: List an oil Additive you'd use / No Comments [Re: SuperDave456] #4190310 08/30/16 04:58 AM
stro_cruiser Offline
Bio/Tech Engine Oil Protectant with LXE® Technology
'00 Accord 4CYL / 5MT
Re: List an oil Additive you'd use / No Comments [Re: SuperDave456] #4190322 08/30/16 05:30 AM
B
BobaLouie Offline
B
Lubegard 60902 Automatic Transmission Fluid Protectant with LXE® Technology
ATP AT-205 Re-Seal
2000 Ford Ranger XLT SuperCab 2WD 4.0 5 spd. auto
168K + and still going...:)
Re: List an oil Additive you'd use / No Comments [Re: SuperDave456] #4190328 08/30/16 05:38 AM
P
Pop_Rivit Offline
P
Whatever additives the oil companies already put in the bottle. Beyond that, I don't waste my money on any of them.
Re: List an oil Additive you'd use / No Comments [Re: SuperDave456] #4190333 08/30/16 05:43 AM
G
Garak Offline
G
Nothing, ever, outside of a ZDDP additive during break in on a flat tappet rebuild.
Plain, simple Garak.
Re: List an oil Additive you'd use / No Comments [Re: SuperDave456] #4190340 08/30/16 05:51 AM
U
UltrafanUK Offline
U
Liqui Moly oil flush and Ceratec are the main additives I have used in my old TDI. If I had any oil leaks that were beyond economic repair, I would also used Motor Oil Saver stop leak additive.
If you are going to use oil additives, it is a good idea to stick to the larger engine oil companies and steer well clear of the back street snake oil mixers.
Re: List an oil Additive you'd use / No Comments [Re: SuperDave456] #4190348 08/30/16 05:59 AM
rooflessVW Offline
Liqui Moly:
Motor Oil Saver
MoS2
Ceratec
Others:
BG MOA
Lubegard BioTech
There are others, but you only asked about engine oil.
"Zed's dead baby, Zed's dead."
Re: List an oil Additive you'd use / No Comments [Re: Pop_Rivit] #4190367 08/30/16 06:34 AM
W
WobblyElvis Offline
W
+1
Re: List an oil Additive you'd use / No Comments [Re: SuperDave456] #4190379 08/30/16 06:52 AM
F
Fsharp Offline
F
Lubegard Bio-Tech
Liquimoly MOS2
MMO
Restoregrin
Re: List an oil Additive you'd use / No Comments [Re: SuperDave456] #4190422 08/30/16 07:38 AM
FowVay Offline
What's that one with the teflon? I can't remember the name but they advertise the slipperiest surface on planet earth.
Also, I meant BG MOA in my previous post. I accidentally put MOS...
Page 1 of 12 1 2 12
