Motorex Supergliss 100K
by Taildragger - 05/28/20 07:30 AM
Dewalt titanium drill bit set
by Donald - 05/28/20 07:29 AM
Spark Plugs - 6.2L GM
by jdw1222 - 05/28/20 07:16 AM
seat belt retracts slowly
by NH73 - 05/28/20 05:19 AM
Bent Jack Stand Ratchet Bar
by The Critic - 05/28/20 01:44 AM
Can a 2005 Volvo go 300K Miles easily?
by VolvoZ - 05/27/20 11:17 PM
Cam specs for '62 Corvette Fulie
by JeffKeryk - 05/27/20 11:06 PM
Grub hub
by Chris142 - 05/27/20 10:52 PM
Fiat 500e In the Stable
by Scout1 - 05/27/20 10:41 PM
Windows 10 2004 (May 2020 Update) is out
by KeithS_NW_Ohio - 05/27/20 08:56 PM
Harley Davidson Lithium LiFe 6Ah Battery 66000174
by DuckRyder - 05/27/20 07:29 PM
Belron Toolbox with collapsible cart. One neat setup
by 10WSmuckers - 05/27/20 07:16 PM
[Cut Open] Mobil 1 M1-209 (5267 miles)
by DuckRyder - 05/27/20 07:15 PM
[Cut Open] FRAM TG8A (30 minutes)
by DuckRyder - 05/27/20 07:06 PM
[Cut Open] Motorcraft FL500S - 5341 miles
by DuckRyder - 05/27/20 06:59 PM
Battery powered 1/2 inch impact wrench
by RazorsEdge - 05/27/20 06:50 PM
Subaru Dealer Filter 7KMI
by Jason_Michaels - 05/27/20 05:52 PM
Vehicle sighting - 1968 AMC Javelin
by Number_35 - 05/27/20 04:22 PM
Looking for help on an old tiller
by BarryBl - 05/27/20 03:28 PM
lr08, BlackMagicVarian, Mustache, mountaingoat, Alegrianyc
71546 Registered Users
95 registered members (4WD, AlienBug, andyd, aba4430, 2K2AcuraTL, adamschoena, 10 invisible), 1,722 guests, and 40 spiders.
Topics305,963
Posts5,283,728
Members71,546
Page 1 of 13 1 2 13
List an oil Additive you'd use / No Comments #4190280 08/30/16 02:33 AM
SuperDave456 Offline OP
I Thought it'd be fun to list Oil Additives you trust and would use or have used.
No other comments please.
I'll go first.
Lubro Moly Engine Oil Saver
Re: List an oil Additive you'd use / No Comments [Re: SuperDave456] #4190285 08/30/16 02:43 AM
K
Kibitoshin Offline
K
Lubro Moly MoS2 and Engine Flush
Redline ZDDP additive
Shin Gekiretsu Shin'ou'hou
02 Chevy Silverado C1500 V8 5.3L
Intertrashional maXXXforce 4300 Box Truck
Re: List an oil Additive you'd use / No Comments [Re: SuperDave456] #4190288 08/30/16 03:04 AM
SR5 Offline
Liqui-Moly Friction Reducer - (MoS2) Molybdenum Disulphide oil additive
Valvoline DuraBlend 10W40 SN & A3/B4 semi-synthetic + Valvoline V06 synblend media filter
Re: List an oil Additive you'd use / No Comments [Re: SuperDave456] #4190295 08/30/16 03:33 AM
F
Farmer Offline
F
Liqui Moly Anti Friction
Liqui Moly Motor Oil Saver
Liqui Moly Pro Line Engine Flush
ATP-205
Re: List an oil Additive you'd use / No Comments [Re: SuperDave456] #4190297 08/30/16 03:54 AM
FowVay Offline
Liqui-Moly MOS2
Liqui-Moly motor oil saver
Schaeffer Moly EP
Camguard (for aircraft engines)
BG MOS
I'm sure there are others... smile
Re: List an oil Additive you'd use / No Comments [Re: SuperDave456] #4190305 08/30/16 04:27 AM
SteveSRT8 Offline
Kreen is the only additive we ever use, and sparingly at that...
"In a democracy, dissent is an act of faith."
J. William Fulbright
Best ET-12.79 @ 111 mph
4340 pounds, Street tires
Just like we go to Publix
Re: List an oil Additive you'd use / No Comments [Re: SuperDave456] #4190310 08/30/16 04:58 AM
stro_cruiser Offline
Bio/Tech Engine Oil Protectant with LXE® Technology
'00 Accord 4CYL / 5MT
Re: List an oil Additive you'd use / No Comments [Re: SuperDave456] #4190322 08/30/16 05:30 AM
B
BobaLouie Offline
B
Lubegard 60902 Automatic Transmission Fluid Protectant with LXE® Technology
ATP AT-205 Re-Seal
2019 Ford Ranger XLT CrewCab FX4 4WD 2.3L 10 speed auto
Re: List an oil Additive you'd use / No Comments [Re: SuperDave456] #4190328 08/30/16 05:38 AM
P
Pop_Rivit Offline
P
Whatever additives the oil companies already put in the bottle. Beyond that, I don't waste my money on any of them.
Re: List an oil Additive you'd use / No Comments [Re: SuperDave456] #4190333 08/30/16 05:43 AM
G
Garak Offline
G
Nothing, ever, outside of a ZDDP additive during break in on a flat tappet rebuild.
Plain, simple Garak.
Re: List an oil Additive you'd use / No Comments [Re: SuperDave456] #4190340 08/30/16 05:51 AM
U
UltrafanUK Offline
U
Liqui Moly oil flush and Ceratec are the main additives I have used in my old TDI. If I had any oil leaks that were beyond economic repair, I would also used Motor Oil Saver stop leak additive.
If you are going to use oil additives, it is a good idea to stick to the larger engine oil companies and steer well clear of the back street snake oil mixers.
Re: List an oil Additive you'd use / No Comments [Re: SuperDave456] #4190348 08/30/16 05:59 AM
rooflessVW Offline
Liqui Moly:
Motor Oil Saver
MoS2
Ceratec
Others:
BG MOA
Lubegard BioTech
There are others, but you only asked about engine oil.
"Zed's dead baby, Zed's dead."
Re: List an oil Additive you'd use / No Comments [Re: Pop_Rivit] #4190367 08/30/16 06:34 AM
W
WobblyElvis Offline
W
+1
Re: List an oil Additive you'd use / No Comments [Re: SuperDave456] #4190379 08/30/16 06:52 AM
F
Fsharp Offline
F
Lubegard Bio-Tech
Liquimoly MOS2
MMO
Restoregrin
Re: List an oil Additive you'd use / No Comments [Re: SuperDave456] #4190422 08/30/16 07:38 AM
FowVay Offline
What's that one with the teflon? I can't remember the name but they advertise the slipperiest surface on planet earth.
Also, I meant BG MOA in my previous post. I accidentally put MOS...
Page 1 of 13 1 2 13
