Anyone ever seen this? 10-month old predator 212cc, probably has 10-12 hours on it tops, in pressure washer use. started great and ran in one sitting for about 3 hours saturday. I shut it down, screwed the pump protector bottle on and went to pull the starter cord, and !ouch!. I fiddled with it a bit, put it away, thumped it a couple of times against the ground, and tried to pull it again the next morning. Nope - spins right into compression stroke then springs back hard.
I went back and checked the warranty - 2 years emissions, 90 days on everything else.
Is it worth taking apart to attempt to repair, or is this thing just a waste?
-Meep
-Meep
