MolaKule
Staff member
When the fluid cools there is a tendency for a partial vacuum to form, and if there are any ingress points, moisture will be sucked in especially when the humidity is high.
Ingress points can be any porous hoses, bad seal on reservoir cap, or bad seal on rack.
