When I said I'm poking fun, I was speaking of the differing opinions and attitudes about oil selection here on BITOG. There really is no need to get your feathers all ruffled.
Here is the text from the RAM 1500/2500/3500 Diesel supplement 7th edition. You can
RAM TRUCKS OWNERS MANUALS download the manual yourself here.
From page 102
Quote:
Engine Oil
Engine Oil Selection
For best performance and maximum protection under all types of operating conditions, the manufacturer recom- mends engine oils that meet the requirements of FCA Material Standard MS-10902, and that are API CJ-4 certified and meet the requirements of FCA LLC.
From page 103
Quote:
Engine Oil Viscosity (SAE Grade)
CAUTION!
Your vehicle is equipped with an advanced technol- ogy Diesel Engine and an emission device designed to limit Diesel Particulate Emissions from being released into the atmosphere. The durability of your engine and life expectancy of this diesel particulate filter emission device is highly dependent on the use of the correct engine oil.
We recommend you use 5W-40 synthetic engine oil such as MOPAR or Shell Rotella that meets FCA Material Standard MS-10902 and the API CJ-4 or ACEA E9/E7 or ACEA A3/B4 engine oil category is required.
From page 121
Quote:
FLUIDS, LUBRICANTS AND GENUINE PARTS Engine
MAINTAINING YOUR VEHICLE 121
Component
Engine Oil
We recommend you use 5W-40 synthetic engine oil such as MOPAR or Shell Rotella that meets FCA Material Standard MS-10902 and the API CJ-4 engine oil category is required.
