Hello all,
Quick question about the Sulfated Ash, wt%, ASTM D 874 test in motor oils. Here is a link to a website that explains the test.
http://www.synforce.com.au/sulphated_ash.html
Here is an excerpt from the test Parameters
[ASTM D 874 Test Parameters
These additives usually contain one or more of the following metals:
•barium
•calcium
•magnesium
•zinc
•potassium
•sodium
•tin
These elements can be present in combined form:
•sulphur
•phosphorus
•chlorine
The sample is ignited and burned until only ash and carbon remain.
After cooling, the residue is treated with sulphuric acid and heated to 775C until carbon oxidation is complete. The ash is then cooled, retreated with sulphuric acid, and heated to 775C to constant weight. The sulphated ash can be used to indicate the concentration of known metal-containing additives in new oils. The result to the nearest 0.001 mass% for samples below 0.02 mass% and to the nearest 0.01 mass% for higher levels are reported as the sulphated ash.]
So, basically the oil is heated and cooled, heated cooled...then tested for how much sulphated ash that is created in the oil (residue) to potentially gum up the turbo and engine? So, seems like this test implies running in engine for long periods of time before cool off helps keep an engine cleaner (less residue created by multiple cool offs)?
Thanks,
•barium
•calcium
•magnesium
•zinc
•potassium
•sodium
•tin
•sulphur
•phosphorus
•chlorine
Thanks,
