Originally Posted By: Ramblejam
Originally Posted By: ST2008
GM never releases anything specific about Dexos' tests and the standards the oil companies have to meet.
They release
everything about it, and it consists of the following:
GM Stochastic Pre-Ignition Test
GM Aeration Test
GM Turbocharger Deposit Test
GM Oxidation and Deposit Test
Sequence VID Test
New European Drive Cycle Fuel Economy Test
GM Valve Train Wear Test
Peugeot Valve Train Scuffing/Wear Test
GM Oil Release Test
Peugeot High Temp Deposits, Ring Sticking, Oil Thickening Test
Sequence VG Low Temperature Sludge Test
M271 Sludge Test
Sequence VIII Bearing Corrosion Test
Wow thanks. Can you provide me a link about all those tests pls ?
I went to Dexos GM website and all I got is this
http://www.gmdexos.com/
