I have a few A/C questions I was hoping a few people could help me with.
With the A/C on my car, maybe it's just me doing a "lucky charm" sort of thing but I shut it off before shutting the engine off, and have the engine on before hitting the button to bring the compressor online. Is this smart? Needless?
Home unit: IIRC we have a 3.5 ton that works fine as far as I know. Can it not be on for 48, even 72 hours straight? What causes some AC's to ice up and break if set to 60F? I like to set mine that low, not because I believe it will ever hit 60 F but because I don't want it cutting in & out. The opinions I have heard & that I have grasped include: That it is mainly a giant de-humidifier, should be on all the time, and for goodness sake do not shut it off and open windows at night. It may go down to 68 but there's all that humidity you spent the whole day getting rid of.
I also believe, as a basement-dweller, that if you feel it's getting too cool, open the door to the basement, and maybe check in an hour if you are still too cool. But leave the A/C cranked.
I was also told, at night just turn it up. Switching the mode from cool to off is a BAD thing.
Are these things correct??
When it gets this hot (OK all you Southerners, it's not 100 F but we still have Humidex advisories), I have a towel over my car seat so the sweat doesn't go from me into the cloth seat. Shirt off, AC cranked (full cold, max fan) and the passenger side vents are closed, and the passenger says it's too cold.... I disagree
Still crazy after all these years
Rob the oil nut
Rob the oil nut
