Reusable DEF container?
Nowthen, MN
We have two trucks at work that use DEF. We get DEF in a 55 gallon drum because it's much cheaper than buying the individual jugs, and we have a hand crank pump to dispense the DEF from the drum. The problem is getting the DEF to the truck. Those jugs aren't meant to be reused, but that's what we've been doing. After a few fills, the spout won't stay on anymore and we have to get a new one. Gas can won't work because the spout won't fit in the DEF fill hole.
So, anyone know of a good container that's designed for this?
Just get a good gas can with a long flexible neck and stencil "DEF" on it.
Edit: just saw what you said... How big is the DEF fill hole?
Originally Posted By: Donald
I buy it at a truck stop at the DEF pump. It's cheaper than buying it in a container for me at least.
Unfortunately, there isn't any place around us or the places we go that has it at the pump. That would be nice though.
