How engine capacity affects fuel consumption?
by NICAT. 12/14/18 01:12 PM
Pep Boys
by Zee09. 12/14/18 12:41 PM
How early in engines life can I start to extend OCI
by Doublehaul. 12/14/18 12:33 PM
EFB and AGM batteries charge faster?
by slybunda. 12/14/18 11:20 AM
97.5 Regal GS climate control illumination
by 71Chevyguy. 12/14/18 11:04 AM
Cool train site for Canadians
by Papa Bear. 12/14/18 10:09 AM
Putting together a groups 3/4/5 synthetic list
by MrWideTires. 12/14/18 10:02 AM
VW Atlas V6 Oil
by motech. 12/14/18 09:32 AM
Great shakes, it's Yahtzee... or a Taurus
by redhat. 12/14/18 09:03 AM
MWI Micro Wave Ignition
by Danno. 12/14/18 08:52 AM
8k Miles on M1 EP 2017 Subaru 3.6
by BISCUT. 12/14/18 08:47 AM
Wrong ATF Fluid in my 07 Chevy Impala
by CM613. 12/14/18 08:39 AM
Hyundai motor oil
by pbm. 12/14/18 08:16 AM
Which Exhaust Manifold Should I Buy
by Miller88. 12/14/18 08:10 AM
Rotella T5 10w30 Ford 6.7L anyone?
by sw99. 12/14/18 07:49 AM
Advice on spark plugs for 90,000 mile Accord
by Chris B.. 12/13/18 11:24 PM
Elec star kit for predator engine...
by SmokeyBear. 12/13/18 11:07 PM
Mecredes Bosch vs Ngk sparks plug
by Rohan. 12/13/18 09:48 PM
Wife problem?
by penguin. 12/13/18 08:04 PM
jcr1293, maxwellk, BlueFog, Frank_G35, captobvious
66681 Registered Users
94 registered members (andyd, bdcardinal, 2004tdigls, aquariuscsm, 4WD, 12 invisible), 1,981 guests, and 41 spiders.
Topics295,062
Posts4,927,086
Members66,681
Most Online2,553
Oct 27th, 2018
2014 Yamaha MT09 10,000 Km/6000mi Delo 400 15W40 #4146274
07/08/16 05:14 PM
07/08/16 05:14 PM
New Zealand
PaulGir Offline OP
PaulGir  Offline OP
New Zealand
This is my first UOA.I was curious to see how the oil stands up to the specified 10,000 km OCI and the low operating temp of this engine (69C - 75C)
Re: 2014 Yamaha MT09 10,000 Km/6000mi Delo 400 15W40 [Re: PaulGir] #4146560
07/09/16 05:53 AM
07/09/16 05:53 AM
Down Under
SR5 Offline
SR5  Offline
Down Under
Hi PaulG,
Nice bike, I like the MT09, I also like Delo 15W-40 as a MC oil.
I think the Delo looked after you fine, given that your Iron numbers are almost the same as the universal averages, yet you went more than twice the average distance.
The oil has sheared or diluted down to a 30 grade. BlackStone say to take the oil further, but I think given the final viscosity you have taken it far enough. I would keep to the factory OCI.
Castrol GTX Ultraclean 15W40 A3/B3 + Wesfil-Cooper Z154
Re: 2014 Yamaha MT09 10,000 Km/6000mi Delo 400 15W40 [Re: PaulGir] #4146861
07/09/16 02:37 PM
07/09/16 02:37 PM
New Zealand
PaulGir Offline OP
PaulGir  Offline OP
New Zealand
That's my feeling too.I'm happy to do 6000mi OCI's.30 grade is ok as the prime recommendation from Yamaha is a 10W-30 but 15W-40 is listed as acceptable in this climate.Temperature extremes here are 5C to 30C.
Re: 2014 Yamaha MT09 10,000 Km/6000mi Delo 400 15W40 [Re: PaulGir] #4147583
07/10/16 01:27 PM
07/10/16 01:27 PM
Cincinnati
donnyj08 Offline
donnyj08  Offline
Cincinnati
Very nice! I have an XSR awith the same triple. I'm glad I went with a HDEO in mine at 96mi. I went with Delvac 1300 15w40 in mine.
It looks like Delo does excellent in these engines!
2008 Silverado Z71 LT 90k Maxlife FS 5w30
2010 Ford Escape 172k QSUD 5w20
2016 Yamaha XSR900 12k, Rotella 15w40 Yamaha Filter.
Re: 2014 Yamaha MT09 10,000 Km/6000mi Delo 400 15W40 [Re: PaulGir] #4148181
07/11/16 07:33 AM
07/11/16 07:33 AM
Cedar Park, TX
sunruh Offline
sunruh  Offline
Cedar Park, TX
yes the 1.8% fuel totally ruins your flash and susvis.
pretty good numbers overall with so much fuel.
you need to figure out why you have so much fuel in the oil.
there is NO reason to try any other oil if this one is cheap for you to purchase.
steve
motorcycle oil myth buster
Re: 2014 Yamaha MT09 10,000 Km/6000mi Delo 400 15W40 [Re: PaulGir] #4148446
07/11/16 02:33 PM
07/11/16 02:33 PM
New Zealand
PaulGir Offline OP
PaulGir  Offline OP
New Zealand
I have been thinking about possible causes for the fuel dilution.
1. When I took the sample,I warmed the bike from cold at idle (without going for a ride) and drained the oil when it was up to temperature.
2.Most of the riding I do is 75 km trips (46mi) around 50 mins.I'll let the bike warm up for 5 mins from cold then do the 75 km ride then later return repeating the warm up etc.I do this around once a week.The bike runs at around 72 C and I've checked the oil temp with a digital thermometer and the oil temp is the same.
3.These bikes were criticised for jerky on/off throttle action.An owner in Australia had found this to be largely due to the lean fuel air ratio when running in closed loop mode.Closed loop runs A/F at 14.7:1.When the mode switches to open loop the A/F goes to around 13.5:1.The Australian guy developed an electronic device that intercepts the signal from the O2 sensor and tweaks it so the A/F runs at 13.4:1 in closed loop.This makes the throttle response in closed loop far less abrupt.But it does make the mixture much richer in closed loop.
Blackstone commented that the low temperature of the engine may be the reason for the high fuel in the oil.
Re: 2014 Yamaha MT09 10,000 Km/6000mi Delo 400 15W40 [Re: PaulGir] #4148960
07/12/16 06:16 AM
07/12/16 06:16 AM
Asia
Tay Offline
Tay  Offline
Asia
is this Delo 400 rated at CJ4 or CI4+?
Re: 2014 Yamaha MT09 10,000 Km/6000mi Delo 400 15W40 [Re: PaulGir] #4148999
07/12/16 07:15 AM
07/12/16 07:15 AM
Cedar Park, TX
sunruh Offline
sunruh  Offline
Cedar Park, TX
your engine warmup for taking the sample was not close to ideal. it needed a ride before hand.
Re: 2014 Yamaha MT09 10,000 Km/6000mi Delo 400 15W40 [Re: sunruh] #4150157
07/13/16 03:27 PM
07/13/16 03:27 PM
New Zealand
PaulGir Offline OP
PaulGir  Offline OP
New Zealand
Any suggestion as to how much this would have affected the fuel value?
Re: 2014 Yamaha MT09 10,000 Km/6000mi Delo 400 15W40 [Re: Tay] #4150162
07/13/16 03:31 PM
07/13/16 03:31 PM
New Zealand
PaulGir Offline OP
PaulGir  Offline OP
New Zealand
CI-4+
Re: 2014 Yamaha MT09 10,000 Km/6000mi Delo 400 15W40 [Re: PaulGir] #4150690
07/14/16 06:13 AM
07/14/16 06:13 AM
Cedar Park, TX
sunruh Offline
sunruh  Offline
Cedar Park, TX
it is very hard to say how much fuel a ride would removed.
provided you didnt sit and idle.
for all we know all of the fuel could have been from your idle warmup.
Re: 2014 Yamaha MT09 10,000 Km/6000mi Delo 400 15W40 [Re: PaulGir] #4450969
07/06/17 03:59 AM
07/06/17 03:59 AM
Ky
CaspianM Offline
CaspianM  Offline
Ky
Why moly is so high for this oil in the sample? Anyone?
14 Dodge Durango
15 Yamaha FZ09
13 Lexus CT200h(M1 0W-20)
15 Yamaha Bolt (FF)
08 Suzuki B-King M1(4T)
10 Xterra SE
06 VTX-1300C
05 Honda 919
Re: 2014 Yamaha MT09 10,000 Km/6000mi Delo 400 15W40 [Re: PaulGir] #4452466
07/07/17 03:09 PM
07/07/17 03:09 PM
Greece
Panos Offline
Panos  Offline
Greece
Blackstone makes this clear on their site:
Run the engine before you take the sample to get the oil at operating temperature (driving about 20 minutes should do it). Getting the oil up to operating temperature should help cook out any normal moisture or fuel build-up.
Clearly this is not to idle the engine from cold. You should change the oil shortly after an actual trip.
You should also stop warming up your engine in idle before every ride. This is truly a bad habit in every aspect
Ford fiesta 1.6 mk6 Motul specific 913D/Motul Gear 300
Kawasaki ninja 250r Motul 5100 10w40
Honda cbr600f Pc41 Motul 7100 10w30
