Maxima Pro Plus 20/50 syn bike oil
by Truckedup. 03/21/19 04:54 PM
CHAMPION COS 3593A **NEW** CUT OPEN
by 53' Stude. 03/21/19 04:28 PM
NAPA PROSELECT 21348 CUT OPEN
by 53' Stude. 03/21/19 04:21 PM
Atlanta No Nonsense Honda dealer
by DuckRyder. 03/21/19 04:16 PM
Echo (PAS) - Good, Bad, Other?
by GemStater. 03/21/19 04:06 PM
Serpentine Belt - When To Change?
by Propflux01. 03/21/19 03:08 PM
Magnetic Out, ST in at Wally Auto Care Center.
by csandste. 03/21/19 02:26 PM
One license plate in a Two-Plate State
by bunnspecial. 03/21/19 02:07 PM
TPMS Units Honda
by Chester11. 03/21/19 01:58 PM
Another brake question
by supton. 03/21/19 01:54 PM
BOUGHT WRONG OIL FILTER
by IBelieveinlube. 03/21/19 01:47 PM
miscible ester, using is as oil additive ?
by pep808. 03/21/19 01:23 PM
LT Oil Temps
by StillLearning. 03/21/19 12:44 PM
What kind of lug nut is this?
by LeakySeals. 03/21/19 12:38 PM
Need help finding a riding mower with $1,500 budget
by MetalSlug. 03/21/19 11:55 AM
Volvo 2.0 Turbo
by Ddub. 03/21/19 11:43 AM
Got a busted crankshaft!
by Chris142. 03/21/19 11:18 AM
Paperboy, Flinch, AlanGonzales, Jrealstreeter, DarkFrontier
67576 Registered Users
102 registered members (2009Edge, 53' Stude, addyguy, 240_Ed, 38Chevy454, 77GrandPrix, 16 invisible), 2,084 guests, and 64 spiders.
Topics286,203
Posts4,904,136
Members67,576
Most Online2,967
Mar 10th, 2019
15w60 full synth in Hydro Gear PG pumps & motors #4145569
07/07/16 04:42 PM
07/07/16 04:42 PM
New South Wales, Australia
redeye Offline OP
redeye  Offline OP
my gravely compact pro 34 has hydro gear 10cc pumps & motors. Its due for its 1st oil change - I have some 15w60 full synthetic (Penrite HPR15) and wonder if it would be safe to use? It would currently have 20w50 dinosaur oil in it and I would be draining from the filter so it won't be a 100% removal....is it ok for synth & dino to be mixed?
Re: 15w60 full synth in Hydro Gear PG pumps & motors [Re: redeye] #4150488
07/13/16 10:36 PM
07/13/16 10:36 PM
Houston, Texas
motor_oil_madman Offline
Houston, Texas
The dino syth mix doesn't matter and hasn't been an issue since the 70's. It probably wouldn't matter, but why not just use either 15w50 or 20w50 like recommended? I'm not sure how cold it gets in Australia, probably not very, but I know on my gravely it takes a few minutes for the hydros to warm up and loosen up so to speak. It's hard for me to explain.
2007.5 dodge cummins 6.7 liter. Chevron Delo400 15w40. 7000 mile or 250-300hr intervals.
Re: 15w60 full synth in Hydro Gear PG pumps & motors [Re: redeye] #4395942
05/04/17 05:24 AM
05/04/17 05:24 AM
Pa, USA
NH73 Offline
NH73  Offline
Pa, USA
Hydro Gear has a min. viscosity but not a maximum. So yes, it should work. If its what I think it is, most of fluid do drain out.
2017 Toyota RAV4 Hybrid
2004 Ford Explorer Sport Trac
2012 Gravely ZT XL 48 w/ Kawasaki FR730
Re: 15w60 full synth in Hydro Gear PG pumps & motors [Re: redeye] #4395958
05/04/17 05:57 AM
05/04/17 05:57 AM
Middle of Iowa
DriveHard Offline
DriveHard  Offline
Middle of Iowa
Why not use an ISO 68 hydraulic fluid? It would perform better in this application. Engine oil is only specified because it is easier to obtain.
Smile, it increases your face value
2013 Fiat 500 Abarth mod heavy (my DD)
2018 Alfa Romeo Stelvio TI Sport (wife's)
2011 Silverado Crew Cab LT 6.2L/6spd (tow pig)
2007 Nissan Xterra (trail toy)
Re: 15w60 full synth in Hydro Gear PG pumps & motors [Re: DriveHard] #4410180
05/21/17 08:15 AM
05/21/17 08:15 AM
Houston, Texas
Houston, Texas
Says not to use hydraulic fluid, but is this because people might use the wrong kind? Looks like their is three different thicknesses, iso68 being the thickest.
Re: 15w60 full synth in Hydro Gear PG pumps & motors [Re: redeye] #4410470
05/21/17 01:25 PM
05/21/17 01:25 PM
down in the park
Jetronic Offline
Jetronic  Offline
down in the park
I suppose you need hydraulic fluid with zinc, ashless exists aswell but if the system required that they wouldn't recommend engine oil.
AR Giulietta 2.0 JTDM-2 -- Total Quartz 9000 Energy 0w30
Hankook Ventus Prime 2 215/50R17 (front)
Pirelli P7 Cinturato 225/45R17 (rear)
Re: 15w60 full synth in Hydro Gear PG pumps & motors [Re: Jetronic] #4410969
05/21/17 10:54 PM
05/21/17 10:54 PM
Houston, Texas
Houston, Texas
There is a guy on youtube that repairs these. He said the guy brought the mower in and used hydraulic fluid. The machine wouldn't even move forward hardly. Maybe he used the wrong grade of hydraulic fluid?
Re: 15w60 full synth in Hydro Gear PG pumps & motors [Re: redeye] #4411337
05/22/17 12:50 PM
05/22/17 12:50 PM
down in the park
Jetronic Offline
Jetronic  Offline
down in the park
The only reason I can think of that the machine won't move, is because the pump is worn and can't pressurise properly with thinner oil. I'd also look into stick/slip action when lightly loaded, riction modiiers might be needed?
You're using 20w50 now, why change?
Re: 15w60 full synth in Hydro Gear PG pumps & motors [Re: redeye] #4411574
05/22/17 06:26 PM
05/22/17 06:26 PM
Houston, Texas
Houston, Texas
I use mobil 1 15w50. Says you can use either. Just wondering why a hydraulic system calls for motor oil, why not use hydraulic fluid like normal.
Or is a hydro gear pump and wheel motor not a true hydraulic system?
Re: 15w60 full synth in Hydro Gear PG pumps & motors [Re: motor_oil_madman] #4465871
07/21/17 08:23 AM
07/21/17 08:23 AM
Middle of Iowa
DriveHard Offline
DriveHard  Offline
Middle of Iowa
Yup, they specify engine oil because it is easy to get, and there is a higher chance people will choose the correct viscosity. I will say that an SAE crankcase oil of weight 50 is a THICK hydraulic fluid and might be hard to find...I think it is equal to an ISO 150 or 220 grade hydraulic fluid. If it was my machine I would be running the ISO 220 hydraulic fluid.
UNLESS you run it in the winter...then you might want to stick with the multi-grade oil.
