Originally Posted By: crazyoildude
Not that i don't believe you but Jay from Fram Claims they don't use louvers and don't plan on changing to them because there is no technical benefit to doing so, His words..
The manufacturing of oil filters can be a cut-throat business. The profit on some oil filters might only be pennies, or possibly a break-even for some numbers. I suspect that the real reason some manufacturers went to louvers is so they don't have to mess with the millions of "donut-holes" that need to be disposed of after punching them out of the sheet metal when making the center tube. You might need an employee with a forklift hauling away a skid of punched metal wafers every couple of hours and then they have to make arrangements to take them to a recycling center. With louvers, there is no need to worry about the cost of the waste... Who knows?
For a person who claims to have run an engine rebuilding shop for decades, me thinks you worry too much about a problem that really shouldn't exist, provided that the filter was manufactured properly.
