Originally Posted By: DakAttack
Cool thanks
You're welcome
Originally Posted By: WellOiled
DuckRyder - are the inlet holes polished so they don't cut the ADBV?
They are not. Note that the tapping plate design is not the same as the BLUE and the BLUE ONE is actually quite a bit sharper. The way the ADBV fits in these contact with the holes is limited, the valve seals near the threads and on the raised ring outside the holes. I don't believe the ADBV could be pierced, but it could be abraded.
I don't care for the flashing inside the holes either.
Thanks for the post.
You are welcome.
