Originally Posted By: robertcope
The factory recommended 90WT, but apparently that was before the weight specifications changed, so a modern 90WT is supposedly a little thinner than what the factory would have been recommending. That's my understanding, anyhow. I found a chart at some point in the past that indicated this was correct, but I can't find it right now. Maybe someone else can chime in on that.
robert
I remember reading something along those lines some years ago when I had my S2K and the consensus was that the 75/110 was a better match spec wise with the OEM SAE 90.
robert
