air suspension on a towed trailer?
by columnshift. 03/25/19 11:57 PM
AeroShell W100 SAE50 in Motorcycles?
by CCI. 03/25/19 11:02 PM
Spark plug torque when using anti-seize
by Reddy45. 03/25/19 10:58 PM
My kid is 8 now - use the front seat?
by y_p_w. 03/25/19 10:53 PM
2005 Pontiac GTO | 44,750 miles | 6-Speed
by Georgiey22. 03/25/19 10:39 PM
GWR Silencer Spray
by agpatel. 03/25/19 10:30 PM
Fuel line insulation to remedy vapor lock?
by motor_oil_madman. 03/25/19 10:22 PM
Running a fan to reduce humidity
by motor_oil_madman. 03/25/19 10:15 PM
stuck grease zerk on my JD tractor
by PaulH. 03/25/19 09:33 PM
S&W M&P 2.0 9MM Range Time
by 2015_PSD. 03/25/19 09:26 PM
Poor quality Ford wheel finish...
by gregk24. 03/25/19 09:12 PM
2013 GMC SIERRA PICKUPS
by Honda2003. 03/25/19 09:10 PM
Fighting HOA - anyone have any luck?
by pezzy669. 03/25/19 09:05 PM
Here's an oldie "Riding a film of oil"
by dbias. 03/25/19 08:47 PM
'14 Mopar 62TE transmission service?'s
by sloinker. 03/25/19 08:25 PM
Dodge Transmissions (Humor)
by StevieC. 03/25/19 07:57 PM
How a differential works
by StevieC. 03/25/19 07:37 PM
My first!
by BigMoneyGrip. 03/25/19 07:20 PM
DCDMan, silverbullet21, gentzel, ksu90, SMA2020
67622 Registered Users
40 registered members (Ag76, carlprop, clinebarger, Bailes1992, Chris142, anndel, 1 invisible), 788 guests, and 61 spiders.
Topics286,440
Posts4,908,215
Members67,622
Most Online2,967
Mar 10th, 2019
Honda tensioner #4138486
06/29/16 07:00 PM
06/29/16 07:00 PM
NY
greasegunn Offline OP
NY
The hydraulic tensioner may be going on my 2010 Civic. Is this something that I can can replace with an aftermarket part or should I stick with a Honda original?
Re: Honda tensioner [Re: greasegunn] #4138497
06/29/16 07:09 PM
06/29/16 07:09 PM
MA, Mittelfranken.de
Trav Offline
Trav  Offline
OE is probably your best bet but look at a Dayco at AA. They have been repacking OE stuff for some German and Japanese cars.
Look at the COO on the box and the parts, if its not Chinese go home order online with a coupon and go back and pick it up or if your a real [censored] like me order it over the smartphone right there in the store. LOL
Re: Honda tensioner [Re: greasegunn] #4138582
06/29/16 08:54 PM
06/29/16 08:54 PM
New England
gathermewool Offline
New England
Symptoms? Mine has rattled for the past couple of years, never getting worse and only bad in cold weather. It also compressed smoothly when I replaced the serpentine belt. This leads me to believe that it's the pulley.
'14 Forester XT FA20DIT (Cobb Stage 1)
Edge 0W-40 + FU filter (64,774 miles)
'15 Legacy FB25 (OEM Stage, uh, neg. 7?)
Edge 0W-20 + FU filter (40,803 miles)
Re: Honda tensioner [Re: greasegunn] #4138614
06/29/16 09:17 PM
06/29/16 09:17 PM
California
Kool1 Offline
Kool1  Offline
California
You are referring to the timing chain tensioner, correct? I thought they are almost bullet proof on a Honda. Are you having specific problems that lead you to believe your timing chain tensioner is going bad?
Re: Honda tensioner [Re: greasegunn] #4138646
06/29/16 10:07 PM
06/29/16 10:07 PM
MN
Yup Offline
Yup  Offline
MN
I've found most OE parts are same, cheaper, or barely more expensive than the auto part retailers. I'd go OE, personally.
Re: Honda tensioner [Re: greasegunn] #4138677
06/29/16 10:55 PM
06/29/16 10:55 PM
Trav Offline
Trav  Offline
I just looked at a picture of it for a 1.8. If the hydraulic cylinder is wet the tensioner is shot, if its dry and has good tension you probably just need a pulley.
Straightforward stuff, easy to change.
Re: Honda tensioner [Re: Kool1] #4138996
06/30/16 10:28 AM
06/30/16 10:28 AM
NY
NY
Sorry - I wasn't clear - the serpentine belt tensioner.
Re: Honda tensioner [Re: Trav] #4139000
06/30/16 10:31 AM
06/30/16 10:31 AM
NY
NY
Thanks Trav. Hopefully I can track it down this weekend. I have some issues with my hearing so pinpointing noise related problems is often problematic for me.
Re: Honda tensioner [Re: gathermewool] #4139007
06/30/16 10:40 AM
06/30/16 10:40 AM
NY
NY
Yes - I'm getting a rattling noise too - trying to pinpoint it down - mainly on cold starts and then eventually goes away.
Re: Honda tensioner [Re: greasegunn] #4139036
06/30/16 11:21 AM
06/30/16 11:21 AM
New York
tdpark Offline
tdpark  Offline
New York
I just replaced mine, I started a mooing sound, the sound was the belt starting to go and I had all kinds of play in the pulley.
Re: Honda tensioner [Re: tdpark] #4139129
06/30/16 12:54 PM
06/30/16 12:54 PM
NY
NY
Thanks - did you pull the belt off to check for play?
Re: Honda tensioner [Re: greasegunn] #4139138
06/30/16 01:02 PM
06/30/16 01:02 PM
New York
tdpark Offline
tdpark  Offline
New York
I did not have to- you could see it wobbling and the belt was starting to get chewed up. When they finally got the tensioner out- there was play in the pulley, looked and felt liked it was going to fail in a few places, they could not just fix the pulley as it had chewed into the assembly. The van is at 288k and this was the original tensioner. I have no idea how I got this far on the original factory tensioner.
Re: Honda tensioner [Re: tdpark] #4139179
06/30/16 01:44 PM
06/30/16 01:44 PM
pennsylvania, usa
dlayman Offline
dlayman  Offline
pennsylvania, usa
Are you referring to the drive or the timing belt? I just started getting the same sound on my Civic with about 300k. I expect its the same problem, although the drive belt doesn't look chewed up yet. How much did the repair cost? Thanks.
Re: Honda tensioner [Re: greasegunn] #4139191
06/30/16 02:04 PM
06/30/16 02:04 PM
New York
tdpark Offline
tdpark  Offline
New York
Drive belt, was about $220 including parts and labor.
Re: Honda tensioner [Re: tdpark] #4149352
07/12/16 03:33 PM
07/12/16 03:33 PM
NY
NY
So I "exercised" the tensioner by slowly putting it through its full range of motion a few times. Noise seems to have gone away. Of course, cold starts are not that cold this time of year. We'll see how things are when Fall comes around.
