Delo 400 SAE 20
KV40C 61
KV100C 8.5
HTHS >2.9 approx.
P .069
Z .076
SA .95
Flash 236C
This engine oil would likely pass 10W cold performance, therefore be labeled 10W20.
Comparable 0w20 and 5W20 engine oils with KV100C of 8.5 typically have 2.7 HTHS.
If a mono-grade SAE20 was blended to the grade maximum of 9.3/KV100C, HTHS would be approximately 3.1
For engines that are designed to run on XW20 engine oil and operating in moderate to very hot climates, low saps SAE20 is an option to consider.
KV40C 61
KV100C 8.5
HTHS >2.9 approx.
P .069
Z .076
SA .95
Flash 236C
