125 years.
by Silk. 09/19/18 12:38 AM
How a VW DSG Transmission works
by StevieC. 09/18/18 10:42 PM
Full Synthetic vs HM Full Synthetic
by SierraMan. 09/18/18 10:06 PM
Champion AGM batteries
by bbhero. 09/18/18 08:53 PM
General opinion about Cooper CS5 Ultra?
by dan_erickson. 09/18/18 08:37 PM
Rotella Online Rebate
by PumpPusher. 09/18/18 08:13 PM
Audi A4 vs Volkswagen CC...or good old Passat?
by KCJeep. 09/18/18 07:19 PM
GM 454 engine
by dirtymudder. 09/18/18 07:13 PM
High Performance Motorcycle oil...which one?
by Neiz15. 09/18/18 06:50 PM
Need help High Performance Motorcycle oil?
by Neiz15. 09/18/18 06:38 PM
MC FL-500S CUT OPEN
by 53' Stude. 09/18/18 05:15 PM
FORD FACTORY FILTER CUT OPEN
by 53' Stude. 09/18/18 05:06 PM
2019 Harley Davidson FXDR 114
by DuckRyder. 09/18/18 04:59 PM
USS Forrestal question
by cjcride. 09/18/18 03:52 PM
Breaker Box
by Throt. 09/18/18 03:00 PM
Honda metal fuel tank seam leak
by wing0. 09/18/18 02:49 PM
Cracked single stage paint
by JHZR2. 09/18/18 01:45 PM
Options versus dealer oil changes
by Schmoe. 09/18/18 01:34 PM
Longevity of Mercon LV in a 2017 Ford Escape?
by mrdctaylor. 09/18/18 01:24 PM
vortex64, 19074, Redright9, Clif67, scotstr
66011 Registered Users
21 registered members (4D56, Bailes1992, bernau, csandste, ctechbob, BlakeB, 2 invisible), 778 guests, and 27 spiders.
Topics290,617
Posts4,847,566
Members66,011
Most Online3,590
Jan 24th, 2017
Mazda 3 Timing Belt #4123489
06/13/16 11:28 PM
06/13/16 11:28 PM
Central Texas
borgward Offline OP
borgward  Offline OP
Central Texas
I am considering getting a 2016 Mazda 3 2.0 litre. Looking under the hood I saw that it might be extremely difficult to change the timing belt. The first generation did not look too hard to work on. Pretty much like working on a 3rd generation Escort. Did not see anything on YouTube.
Re: Mazda 3 Timing Belt [Re: borgward] #4123493
06/13/16 11:39 PM
06/13/16 11:39 PM
Denmark
shDK Offline
shDK  Offline
Denmark
it uses a timing chain. No belt
Re: Mazda 3 Timing Belt [Re: shDK] #4123498
06/13/16 11:50 PM
06/13/16 11:50 PM
Central Texas
borgward Offline OP
borgward  Offline OP
Central Texas
My Bad. Just saw that at http://www.underhoodservice.com/mazda-s-skyactiv-technology/. I noticed it has 13:1 compression ratio. Does a high compression ratio affect wear? Still want to know about changing the timing chain. I am guessing it's probably good for 200,000 miles.
Re: Mazda 3 Timing Belt [Re: borgward] #4123523
06/14/16 12:46 AM
06/14/16 12:46 AM
Central IA
Robenstein Offline
Robenstein  Offline
Central IA
A good timing chain can go for much much longer than that. We had a car that we took to the junkyard at 285k. We took it to the junk yard because the body rotted out....still had the original timing chain in it. Quality of materials as well as quality of care will limit or actualize the potential.
2011 Triumph Speedmaster
1986 Chevy Monte Carlo SS
1970 Chevy Nova
2006 Scion TC
Re: Mazda 3 Timing Belt [Re: borgward] #4123694
06/14/16 08:03 AM
06/14/16 08:03 AM
Ohio
SpencerHSS Offline
SpencerHSS  Offline
Ohio
My girlfriend purchased a 2012 Mazda 3, 2.0L with 32k on it. Her dad went out and bought a 2012 Mazda 3, same engine with just 120 more miles on it, that same day that she bought hers. Great little car so far, hers has a slight stumbling/shudder issue when cold, so I've been wrenching each weekend trying to narrow it down, not worried about it, only lasts 2-3 seconds and happens a few days a week. Mazda is a great brand, I highly recommend the 3 and it's engine. I always joke if she would have bought the better looking hatch over the sedan that her car wouldnt have the shaking issue lol. Her dad's 3 runs great. At almost 60k miles now.
10 Chevrolet HHR Boring Daily
94 Mazda Miata Torsen/5 spd Winter daily
95 Mazda Miata Torsen/5 spd/M45 SC AutoX/Track
Re: Mazda 3 Timing Belt [Re: borgward] #4123698
06/14/16 08:11 AM
06/14/16 08:11 AM
Ohio
SpencerHSS Offline
SpencerHSS  Offline
Ohio
But it is easy to work on in all the maintenance I've done so far. As far as the chain goes, unless something is making noise, chains arent really worth replacing, they are made to outlive the engine. If something is wrong with it, itll more than likely show its ugly face during the warranty period (worth noting that used Mazdas typically have a longer warranty period than brand new).
Girlfriend's dad does complain that sometimes he wishes he would have went with the larger 6, as he replaced his Camry with the 3, which is noticeably smaller.
Re: Mazda 3 Timing Belt [Re: borgward] #4123737
06/14/16 09:14 AM
06/14/16 09:14 AM
Canada
nobb Offline
nobb  Offline
Canada
It's common in a timing belt change to also change the water pump. With timing chain systems, is it also assumed that the water pump lasts the life of the engine?
Re: Mazda 3 Timing Belt [Re: borgward] #4123739
06/14/16 09:18 AM
06/14/16 09:18 AM
Central Texas
borgward Offline OP
borgward  Offline OP
Central Texas
Hmm - Where is the water pump located on that engine? Good issue to bring up.
Re: Mazda 3 Timing Belt [Re: borgward] #4123744
06/14/16 09:23 AM
06/14/16 09:23 AM
DFW
DBMaster Offline
DBMaster  Offline
DFW
The water pump on the Skyactiv engine is driven by its own dedicated vbelt, not the serpentine belt. It is not behind or under any engine coverings. It's made to be especially low drag - part of the whole "Skyactiv" philosophy. It'll be interesting to see how long it lasts (I have a 2012 Mazda3), but I'll bet it will be a LONG time.
If you want something to keep an eye on make it the hydraulic tensioner for the serpentine belt. The Critic showed one that he changed for a customer. It was all gunky on the outside due to seepage of hydraulic fluid. Mine is starting to get a little "wet" at 63,000 miles. I have found them online from Mazda dealers for $95 so when the time comes I guess I can handle it.
Re: Mazda 3 Timing Belt [Re: SpencerHSS] #4512374
09/10/17 02:33 PM
09/10/17 02:33 PM
Central Texas
borgward Offline OP
borgward  Offline OP
Central Texas
Originally Posted By: SpencerHSS
chains... are made to outlive the engine.
That would depend on how good a chain was used. They come in a variety of toughness. I was in a BMW shop and asked what they were doing - replacing the chain at about 100,000 miles. That was a pull the engine job. The shop owner said they get a lot of them. As with some Mazda 3's the culprit was the tensioner. Its a moot point about how good the chain is if the tensioner fouls it up. You still have to go to a lot of trouble repairing it.
I remember in the good old days replacing timing chains was pretty routine.
Re: Mazda 3 Timing Belt [Re: borgward] #4513504
09/11/17 05:40 PM
09/11/17 05:40 PM
Dacono, CO
Bladecutter Offline
Bladecutter  Offline
Dacono, CO
Have you even driven the car yet?
You sure are busy looking for reasons to rule it out, why not just forget about it, and move on to a different car?
BC.
2014 Mazda CX-5 Touring (Soul Red)
2015 Porsche Cayman
2007 Ducati 848
1988 Honda Hawk GT
Re: Mazda 3 Timing Belt [Re: borgward] #4513753
09/11/17 10:02 PM
09/11/17 10:02 PM
Central Texas
borgward Offline OP
borgward  Offline OP
Central Texas
Ruled it out a long time ago. Thinking something inline engine in the front, real wheel drive. I was just pointing out that chains are not necessarily problem free. A belt has a life limited to 8 years regardless of mileage. A chain's life thought is not limited to time, but to mileage and other factors such as damage from bad tensioner's. I wrote off the Mazda as I could not get a good idea of what it would take to replace the chain. Mazda 3's had a reputation for eating chains in the past. I certainly did not want to have to pull an engine to do that chore. Anyone have any idea what is involved in replacing the chain?
