2000 Buick LeSabre w/ 3800 V6
Went to get gasoline last night. I set the nozzle on trigger lock and let it fill up. The pump shut off at 10.770 gallons. I then pressed the nozzle closely against the filler neck and pumped in another 3.746 gallons. 14.516 gallons pumped total. Why the heck does the pump shut off at almost 4 gallons early ?
