P0171 and P0174
by NavyVet88 - 01/26/20 05:04 AM
Essex Engine Plant (Canada)
by BlueOvalFitter - 01/26/20 03:18 AM
Mopar oil bottles
by Franz - 01/26/20 12:47 AM
Ultra-rare barn find!
by Toy4x4 - 01/26/20 12:11 AM
2015 Hyundai Genesis 5.0L Review
by Nick1994 - 01/25/20 11:56 PM
My doggie had a rough week
by Chris142 - 01/25/20 11:26 PM
Delivery meal kit review - Dinnerly vs HelloFresh
by pezzy669 - 01/25/20 10:32 PM
Eotech Vudu scopes
by OVERKILL - 01/25/20 10:10 PM
'12 Civic burning oil after switch to M1
by sr20detfwd - 01/25/20 09:33 PM
Wix/NAPA Gold and M+H
by Uphill_Both_Ways - 01/25/20 09:06 PM
New seafoam oil stabilizer at AZ
by Chesterr - 01/25/20 08:13 PM
In 3 hours - 730 days and counting
by OVERKILL - 01/25/20 08:12 PM
Pig Parker!
by dishdude - 01/25/20 07:58 PM
NGK Conventional vs. Ruthenium Plugs
by doitmyself - 01/25/20 07:58 PM
Container or funnel?
by Philthy_Phil - 01/25/20 07:24 PM
AC Delco filters at Amazon as little as $1.07
by jayjr1105 - 01/25/20 06:22 PM
Excessive moisture in oil
by mb32 - 01/25/20 05:47 PM
Cover for Jeep + Trailer
by kehyler - 01/25/20 05:34 PM
kwashabcp, ronster, BackToReality, Scopeman, M635_Guy
70527 Registered Users
40 registered members (blufeb95, BobsArmory, bradepb, bbhero, bmod305, Bobaloo22, 3 invisible), 1,235 guests, and 18 spiders.
Topics300,572
Posts5,178,508
Members70,527
20yr old Techumseh runs then quits #4118586 06/08/16 12:51 PM
callbay Offline OP
10HP on a generator. Runs for about 30 seconds then quits. Wait a couple of minutes and it will start and then do the same thing again.
I took the carb bowl off and the float seems to be working ok.
Any Ideas?
Thanks a ton!
Re: 20yr old Techumseh runs then quits [Re: callbay] #4118592 06/08/16 12:54 PM
CT8 Offline
Is there spark?
2015 F150 2.7
2018 F350 6.2
Re: 20yr old Techumseh runs then quits [Re: callbay] #4118597 06/08/16 12:58 PM
SumpChump Offline
It's not getting fuel. something in the line may be letting a trickle through enough to fill the bowl for a time frame which then is used up at a pace too fast for the restricted flow. I'd pull the fuel line and see how the flow is. Also check/take off the fuel tank and get the crud out of there. It could be very small particles blocking a jetting area also.
Re: 20yr old Techumseh runs then quits [Re: callbay] #4118604 06/08/16 01:04 PM
doitmyself Offline
Fuel filter plugged?
Fuel line plugged? Follow SumpChump's advice.
Fuel tank cap not venting? Try starting it without cap.
Re: 20yr old Techumseh runs then quits [Re: callbay] #4118608 06/08/16 01:09 PM
O
OneEyeJack Offline
O
Choke setting?
Re: 20yr old Techumseh runs then quits [Re: callbay] #4118611 06/08/16 01:13 PM
L
lexus114 Offline
L
it doesnt have a low oil shut off on it does it?
2018 Nissan Maxima S
Re: 20yr old Techumseh runs then quits [Re: callbay] #4118629 06/08/16 01:39 PM
callbay Offline OP
Yes, it has spark and it does have a low oil warning system.
Re: 20yr old Techumseh runs then quits [Re: callbay] #4118642 06/08/16 01:47 PM
K
Kawiguy454 Offline
K
Not getting fuel- Partially clogged filter or even gas tank vent is clogged. If its been sitting long time could be a cruddy carb too.
Re: 20yr old Techumseh runs then quits [Re: callbay] #4118645 06/08/16 01:48 PM
M
Merkava_4 Offline
M
First you gotta determine whether it's losing spark or losing fuel. Most of the time it's a fuel deliver problem because carburetors get clogged up real easy. Ignition systems don't get clogged up; they either work or they don't work. Is the ignition system breaker points or electronic magneto; do you know ?
Re: 20yr old Techumseh runs then quits [Re: Kawiguy454] #4118649 06/08/16 01:58 PM
B
Bgallagher Offline
B
+1 this is what I was thinking. I would replace the filter and consider taking the carb out and giving it a good soak/cleaning.
2017 Chevy Traverse - 28k - Delco Dexos 1 and PF63
2014 Chevy Equinox - 22k - Delco Dexos 1 and PF457G
2015 GMC Terrain - 22k- Delco Dexos 1 and PF457G
Re: 20yr old Techumseh runs then quits [Re: callbay] #4118692 06/08/16 02:52 PM
callbay Offline OP
Got it! It was a little piece of hair thickness wire that holds the needle valve to the tang on the float.
I had it in the wrong spot. It was not on the tang. As soon as I put it on the tang it kept running. Maybe it kept the needle valve from opening much.
Thanks BITOG guys!
Re: 20yr old Techumseh runs then quits [Re: callbay] #4118826 06/08/16 05:41 PM
A
andyd Offline
A
Have you cleaned the holes in the main jet yet? You clean the varnish out of the hole in the side of jet Down a little bit below the top. This is all that stuff on the bowl nut. Please post a follow up.
Thick oil is better grin2
Re: 20yr old Techumseh runs then quits [Re: andyd] #4118948 06/08/16 07:52 PM
M
Merkava_4 Offline
M
He actually did, but you didn't read through the posts before posting. grin2
