Did Rotella Ever Have JASO MA Certification?
by BBDartCA - 01/22/20 12:49 AM
Old Tundra Headlamp Upgrade
by JeffKeryk - 01/21/20 09:41 PM
MOVIE: Dr. Dolittle
by Kira - 01/21/20 09:34 PM
Oil weight and Oil Grade
by Snagglefoot - 01/21/20 07:11 PM
Which air filter for RAV 4 Hybrid
by NH73 - 01/21/20 06:44 PM
Finding a good "cold weather" vehicle?
by Vern_in_IL - 01/21/20 06:15 PM
Bough NGK Ruthenium sparkplugs
by cronk - 01/21/20 06:07 PM
HF 30% Off $10 and Under
by TheLawnRanger - 01/21/20 06:02 PM
Stolen Battery-New one on Me
by bunnspecial - 01/21/20 05:29 PM
2006 Acura TSX Buying Advice
by maverickfhs - 01/21/20 04:35 PM
Castrol GTX Diesel 15W-40, CK4
by HDoilDude - 01/21/20 04:30 PM
Combo of P0068 and P307A
by Alfred_B - 01/21/20 04:30 PM
Are the plastic battery trays necessary?
by littlehulkster - 01/21/20 03:18 PM
Amsoil ATV/UTV Powertrain Fluid
by IowaFord - 01/21/20 02:13 PM
Motorcraft FL500s 3,630 miles.
by mpgo4th - 01/21/20 01:36 PM
Xcel Class Action Suit
by John_K - 01/21/20 12:33 PM
RV Freightliner Cummins ISB 6.7 oil question
by 1978elcamino - 01/21/20 11:48 AM
IowaFord, Origami99, reylafo, PastPresMike, RedBeard83
70497 Registered Users
31 registered members (Black_Thunder, bbhero, CB22, Bailes1992, 1WildPig, carlprop, 5 invisible), 1,284 guests, and 25 spiders.
Topics300,415
Posts5,175,284
Members70,497
Installing differentials #4117876 06/07/16 04:16 PM
B
buck91 Offline OP
B
I've done a lot of research over the years and even dabbled in carrier swaps in Ford 8.8's in the past. Thinking about swapping about my open rear dif for an eaton unit in my daily-driver F150 myself but I'm hesitant since its a daily driver.
Talking to some folks on various F150 forums, I know of at least two who installed Eaton's and were able to reuse the stock shims and end up with all measurements within spec. They had friends helping or doing the work, though so they don't know the actual measurements or if carrier bearigns were reused or replaced.
Any thoughts on DIY Ford 9.75 carrier swaps? Like I said, I've researched a lot and played with the Ford 8.8 also. I figure worst case is the stock shims won't do the trick and I need to try to get it lined up with adjustable shims... or have to throw the stock unit back together and end up using a shop. Anybody have any success?
Also, while I'm familiar with the Ford 9.75 I don't have the tech specs like fastener torque values and carrier bearing preload- does anybody have access to that info?
2011 F150 4x4 5.0L
1996 Mustang GT 5spd/ragtop
Re: Installing differentials [Re: buck91] #4117897 06/07/16 04:42 PM
T
Trav Offline
T
I don't know what your skill level is but this can be a difficult job to get the pattern dead nuts on. Do you have all the measuring tools and a inch pound torque wrench with memory?
Check these out, all differentials are basically the same in as much as they need the correct pinion depth, preload and correct pattern.
http://www.differentials.com/technical-help/installation-instructions
PDF
Re: Installing differentials [Re: buck91] #4117906 06/07/16 04:58 PM
spasm3 Offline
I've though about doing a gear change on my avalanche, its 4x4 so both diffs. I'm not sure i want to tackle it, but how do i trust a shop to do it right either?
13 elantra 81k 5w30 synpwr
17 mazda cx-5 17000 miles synpwr 5w30
Re: Installing differentials [Re: spasm3] #4117909 06/07/16 05:16 PM
T
Trav Offline
T
You need a good mechanic, a specialty shop or a dealer with someone able to do the job. Every dealer has a (or should have) real experienced mechanic that can do everything.
Re: Installing differentials [Re: buck91] #4118049 06/07/16 08:43 PM
B
buck91 Offline OP
B
Trav, great link! Seems to have most of the info I lack and a good summary of everything in general.
2011 F150 4x4 5.0L
