supertec cartridge filters
by super20dan - 01/19/20 06:17 PM
More Valvoline on rollback at WM
by jayjr1105 - 01/19/20 06:13 PM
Crossed poles on jumper cables
by 3Aone - 01/19/20 05:33 PM
Napa Gold 7060 7.5K miles
by KenshinHimura - 01/19/20 05:09 PM
Can you move a car with the starter?
by atikovi - 01/19/20 04:49 PM
Leaf spring advice.
by mpack88 - 01/19/20 02:19 PM
Detroit 4-53T swap update.
by A310 - 01/19/20 12:54 PM
Wiper arm tension...
by Loogie - 01/19/20 12:26 PM
Changing Battery
by Char Baby - 01/19/20 12:16 PM
UOA shelf life
by STIcandy - 01/19/20 12:02 PM
2015 Ram Engine Oil
by nemtulea - 01/19/20 12:02 PM
Fram TG7317 1000 miles
by KenshinHimura - 01/19/20 11:57 AM
2013 Escape 2.0 Ecoboost surge
by HoosierJeeper - 01/19/20 10:36 AM
European Tools via Amazon - New Lug Wrench
by JHZR2 - 01/19/20 09:57 AM
Samsung 32 inch 4K curved monitor at Costco
by Cujet - 01/19/20 09:55 AM
2009 corolla 1.8
by Bettez88 - 01/19/20 09:41 AM
Remote key - OEM vs aftermarket
by AZjeff - 01/19/20 08:13 AM
Toyota Tundra Warranty
by Tundra73 - 01/19/20 08:10 AM
Thetarmac, lbstyling, tanpw, JPz521l, KirklanC
70481 Registered Users
118 registered members (atikovi, 53' Stude, Aero540T, AC1DD, alchargo, 13 invisible), 3,301 guests, and 27 spiders.
Topics300,327
Posts5,173,381
Members70,481
Most Online3,825
Jan 19th, 2020
98 toyota corolla do injectors clean the valves? #4117303 06/06/16 08:18 PM
Z
ziggy Offline OP
Z
Hi all. car in question, is 98 corolla CE sedan 4 door model. Icant nothing online, regarding how the fuel injection and valves are set up, other than its EFI ( electronic fuel injected).
My question is...Do the valves gt cleaned with gas,spraying allover the base and top and stem of the valves? Or are they set up so only the bottom base gets sprayed cleaned?
Re: 98 toyota corolla do injectors clean the valves? [Re: ziggy] #4117341 06/06/16 09:09 PM
T
Trav Offline
T
The back of the valve and about an inch up the stem.
Re: 98 toyota corolla do injectors clean the valves? [Re: ziggy] #4117540 06/07/16 07:30 AM
V
Vikas Offline
V
This guy already asked about his "98 Corrolla with GDI".
Re: 98 toyota corolla do injectors clean the valves? [Re: Vikas] #4117560 06/07/16 08:02 AM
H
HerrStig Offline
H
He must be having some trouble with the GD ... I.
Re: 98 toyota corolla do injectors clean the valves? [Re: ziggy] #4117580 06/07/16 08:30 AM
cptbarkey Offline
review this article, it goes in depth on some of what you are alluding to.
http://www.aa1car.com/library/ar1192.htm
Re: 98 toyota corolla do injectors clean the valves? [Re: ziggy] #4117737 06/07/16 12:09 PM
Z
ziggy Offline OP
Z
I only recently found about this GDI intake system recently. IM just a do it yourself mechanic, so to speak. BUt love n like learning automechanics:)
the car, has 84,000 miles on it. Never cleaned the intake, or throttle body. It was my dads car. He used too go too jiffy lube places. I aquired the car, few years ago, and have cleaned it up since...under the oil fill cap, oil was baked on. IGT was burning oil, about 75% a quart in 700 miles. I have done 4,000 mile oil changes since, better filters, and now the car burns only like 25% a quart in 4,000 miles. not bad! Last year, i did the transmission fluid. it was GREY and BLACK coming out. i didnt do the filter, i pulled the return line, turned car on, ran till it sputtered, truned it off, refilled with new fluid, same amount that came out. and the differential too.
The point...i am assuming the intake may or must be a mess! I do have a new gasket, felpro, but waiting to get some mroe money together, too get new or irngs and fuel injector cushions, autozone, as long as the fuel rail is guna be off.
I do run MMO in winter 6 months, and tcw3 3 ozs for 10 gallons, every fill up, shell 87 TT fuel. so....perhaps im better off running seafoam or B12 , spray into into the throttle body as car runs or manifold vaccum line? tan go through the removal of the manifold itself, and maybe just too find thiers no carbon buildup? or their might be.. why i started this post. i would assume the valves are clean then, from TRAV's answer. but the intake i dunno.
Re: 98 toyota corolla do injectors clean the valves? [Re: ziggy] #4117755 06/07/16 12:47 PM
O
Olas Offline
O
By I a cheap USB borescope off eBay and inspect it without pulling it to bits, then you can be sure you're only doing what you need to.
Cable ties should hold it
Re: 98 toyota corolla do injectors clean the valves? [Re: ziggy] #4117922 06/07/16 05:35 PM
T
Trav Offline
T
It doesn't have GDI (Gasoline Direct Injection) it has PFI (Port Fuel Injection that uses Denso (probably blue ones) disc style injectors.
Its normal for the intake to get dirty looking from PCV gasses but that will not cause the sort of buildup found on GDI/DI engines.
Unless it has verified injector issues just clean the throttle body one the car with some CRC throttle body cleaner and throw a bottle of Redline SI1, Techron total fuel system cleaner or Gumout High Milage in the tank and leave the thing in peace.
Throw a new PCV valve at it for good measure.
Re: 98 toyota corolla do injectors clean the valves? [Re: ziggy] #4118285 06/08/16 06:52 AM
V
Vikas Offline
V
Listen to Trav; he is the guy who actually services injector for living. If he is telling you to leave them alone, you should follow his advice.
