Oil weight and Oil Grade
by Snagglefoot - 01/21/20 07:11 PM
Which air filter for RAV 4 Hybrid
by NH73 - 01/21/20 06:44 PM
Finding a good "cold weather" vehicle?
by Vern_in_IL - 01/21/20 06:15 PM
Bough NGK Ruthenium sparkplugs
by cronk - 01/21/20 06:07 PM
HF 30% Off $10 and Under
by TheLawnRanger - 01/21/20 06:02 PM
Stolen Battery-New one on Me
by bunnspecial - 01/21/20 05:29 PM
2006 Acura TSX Buying Advice
by maverickfhs - 01/21/20 04:35 PM
Castrol GTX Diesel 15W-40, CK4
by HDoilDude - 01/21/20 04:30 PM
Combo of P0068 and P307A
by Alfred_B - 01/21/20 04:30 PM
Are the plastic battery trays necessary?
by littlehulkster - 01/21/20 03:18 PM
Amsoil ATV/UTV Powertrain Fluid
by IowaFord - 01/21/20 02:13 PM
Motorcraft FL500s 3,630 miles.
by mpgo4th - 01/21/20 01:36 PM
Xcel Class Action Suit
by John_K - 01/21/20 12:33 PM
RV Freightliner Cummins ISB 6.7 oil question
by 1978elcamino - 01/21/20 11:48 AM
Why I became a pilot and not a doctor...
by jetman - 01/21/20 10:52 AM
Wrong oil or not ?
by M119 - 01/21/20 10:48 AM
30 monograde
by mpack88 - 01/21/20 10:15 AM
Extended life destroys copper?
by mpack88 - 01/21/20 09:49 AM
Project Farm Lucas transmission additive video
by 1978elcamino - 01/21/20 09:43 AM
IowaFord, Origami99, reylafo, PastPresMike, RedBeard83
70497 Registered Users
132 registered members (4WD, 750IX, A310, 67ZL1, 1foxracing, 11 invisible), 2,407 guests, and 25 spiders.
Topics300,410
Posts5,175,151
Members70,497
Oil light comes on before OC, then goes away #4117159 06/06/16 05:54 PM
Dohc98vteC Offline OP
Oil level is fine. This happened just before my last OC , then it went away after the oil change. It will flash sometimes during normal driving, but not all the time. Car in question is the TSX
2018 Elantra Sport DCT
2004 Honda Element EX AWD
Re: Oil light comes on before OC, then goes away [Re: Dohc98vteC] #4117181 06/06/16 06:14 PM
R
Rand Offline
R
bad oil pressure switch?
Re: Oil light comes on before OC, then goes away [Re: Dohc98vteC] #4117208 06/06/16 06:38 PM
P
Popsy Offline
P
Excessive oil shearing?
96 Barchetta, 300V 5W40 | Forfour 95, M1 0W40
Mazda 6 2.3, Castrol 0W30 | Colt Ralliart, 300V 5W40
Re: Oil light comes on before OC, then goes away [Re: Dohc98vteC] #4117213 06/06/16 06:42 PM
O
OneEyeJack Offline
O
Check the connection to the oil pressure sender.
Next, get it checked out by a mechanic.
Re: Oil light comes on before OC, then goes away [Re: Dohc98vteC] #4117228 06/06/16 06:57 PM
J
John_K Offline
J
Had this happen. Change oil filter, problem solved.
2009 Mercury Grand Marquis, 8 cyl auto, 95xxx miles, PU/Fram Ultra
2005 Hyundai Sonata, 4 cyl auto, 99xxx miles, Maxlife/OEM Filter
Current oil stash: 459 qts.
Re: Oil light comes on before OC, then goes away [Re: Dohc98vteC] #4117329 06/06/16 08:52 PM
B
Brybo86 Offline
B
Need more background
Oil used before and after change.
Oil filter used before and after
Miles and time on oil before change?
12 Honda Odyssey 112k
09 Kymco Super8
08 Honda Accord 2.4L 164k
01 Kymco People 50
95 Yamaha Jog
Re: Oil light comes on before OC, then goes away [Re: Dohc98vteC] #4117358 06/06/16 09:51 PM
This was whatever the dealer uses, so new filter each time with the oem spec 5w20 I believe, even though the cap calls for 5w30. The oci is about 3,000 miles.
Re: Oil light comes on before OC, then goes away [Re: Dohc98vteC] #4117405 06/07/16 01:15 AM
G
Gasbuggy Offline
G
Wouldn't be the first Honda I saw that had a pressure sensor fail after 12 years.
Cadillac CTS-V 6.2L 10w30PP
Volvo P1800 Euro L
76 Mercedes 300D Rotella T4
Series III Land Rover VWB
02 Yukon 10w30 PP
01 P71 M1 EP-HM 0W20
95 Accord - 386k. Mobil 2 RIP
Re: Oil light comes on before OC, then goes away [Re: Rand] #4118210 06/08/16 04:31 AM
L
Lubener Offline
L
Agree. I had several go bad over the years, usually they leak. I would get a mechanical gauge on it and verify. I would believe if the pressure is too low, the engine would become noisy.
The "thinking" man's friend.
Re: Oil light comes on before OC, then goes away [Re: Rand] #4118217 06/08/16 04:48 AM
T
Trav Offline
T
+1 If its still running and not making a racket thats 99% the problem.
